IAC diagnosis question?
Old May 13, 2010 | 03:49 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
I have suspected that the IAC in my 89 IROC 5.7 is faulty, but my question is if the IAC is unplugged and you start the car should it idle normally and throw a code to the ECM. The reason I ask is because I had it unplugged, started the car, and it idled fine, but did not throw a code??? Just wondering.
Old May 13, 2010 | 07:27 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: IAC diagnosis question?
How it idles depends on the position of the IAC when you unplug it. If it was idling fine when you unplug it, then it should continue to do so.
No code is normal.
If you have a slightly high idle right after a cold start, but it settles down after a couple of minutes, then your IAC is probably functioning just fine.
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
