Code 32 help anybody?!?!
Old May 26, 2010 | 09:53 AM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
My car has had a code 32 among other problems I'm tryig to narrow down. Just wondering what I can do to troubleshoot/fix my code 32 on my L98. Thanks for any help
Old May 26, 2010 | 10:12 AM
memjr's Avatar
Car: 91 camaro z28
Engine: 5.0 tpi
Re: Code 32 help anybody?!?!
troubleshooting trees and diagrams. might help untill some of the senior members come in
Attached Thumbnails Code 32 help anybody?!?!-87-trans-code-32   Code 32 help anybody?!?!-87-trans-code-32
Old May 26, 2010 | 02:45 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
egr valve is not working right. check the vac line under the throttle body, it goes back to the egr solonoid, then check the vac line from the solonoid to the egr valve. If those are both good then the valve itself maybe sticking, the temp sensor on the side of the valve may have failed, (Check the plug to see that it's still connected) or the passage in the manifold is clogged with carbon. also the solonoid may be bad as well.
Old May 26, 2010 | 03:07 PM
87TAGTA66's Avatar
Engine: 5.7 TPI
sweet guys thanks
Old Feb 18, 2015 | 12:43 PM
TheSilverBullet's Avatar
Car: 1986 Sport Coupe
Engine: 5.0 LG4
My situation is that the solenoid is not grounding out to open EGR. Solenoid works as tested, EGR is new..Is this a ECM issue, perhaps A4 circuit that grounds the solenoid..OR is it false temperature reading from the CTS on the manifold.?. Seeing if I need to pay out 13$ or not-haha
Old Feb 20, 2015 | 03:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You should open your own thread,this one's 5yrs old,Start a New Thread.
Old Feb 25, 2015 | 10:16 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I would be shocked if a Camaro DIDNT have the code 32. seems like a factory option !!
Old Feb 26, 2015 | 11:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
LMFAO
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
