383 tpi
Old Jun 5, 2010 | 01:16 PM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
383 tpi
hello i was wondering if i get a 383 will my stock intake manifold and my fuel injenction from my 350tpi will work good? will it give me any problems? thanx
Old Jun 5, 2010 | 01:21 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: 383 tpi
It will work, but it will choke the engine. You need to port the plenum and runners, and intake manifold at a minimum. An aftermarket intake like the Stealth Ram or Super Ram would be FAR better.
Old Jun 5, 2010 | 01:42 PM
jll87TA's Avatar
Axle/Gears: stock
Re: 383 tpi
thanx, so i just need to port the plenum, runners and intake manifold? will i have problems with my comp?
Old Jun 5, 2010 | 02:15 PM
Stephen's Avatar
Car: 87 GTA
Re: 383 tpi
You'll benefit a lot more from programming, than from porting to the physicals. You'd be surprised at what the stock parts can make on a 383. Torque happy, yes, but a GREAT street engine!
Old Jun 5, 2010 | 02:27 PM
jll87TA's Avatar
Axle/Gears: stock
Re: 383 tpi
So programming the computer would be better than porting? Where can I program it?
Old Jun 5, 2010 | 02:47 PM
87WS6's Avatar
Re: 383 tpi
It will certainly need programing, but I'd port all that stuff while I was at it. TPI is pretty restrictive as it is on a 350.
Old Jun 5, 2010 | 02:48 PM
Stephen's Avatar
Car: 87 GTA
Re: 383 tpi
I've seen a heads & cam only....stock throttle body, stock plenum, stock runners & stock intake (+programming) make 410hp/501ft lbs that made. And the engine looked stock, except for the headers, afterwards
The heads were a big contributing factor....TFS heads.....But that shows that the stock upper parts can support power.
Granted.....Edelbrock runners & an intake bumped the same combo by 25hp (torque only went up by 1 ft lb) , but those parts aren't cheap for only 25hp & I have no idea what kind of/if more programming was done.
Just by extrude porting the plenum & intake, adding big tube runners (probably tuning too) & a 52mm throttle body, it hit 451hp/534ft lbs torque!
Old Jun 5, 2010 | 02:57 PM
jll87TA's Avatar
Axle/Gears: stock
Re: 383 tpi
Thanx for the advice! Do you know where I cant have it program?
Old Jun 5, 2010 | 03:37 PM
Stephen's Avatar
Car: 87 GTA
Re: 383 tpi
An Accel DFI was used instead of the stock type PROM, so that tuning changes were much easier than burning chip after chip after chip, to see what/if improvement was made (or lost) after the parts changes.
Old Jun 6, 2010 | 12:36 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: 383 tpi
Kid, in all seriousness... you dont have a CLUE what you're doing... dont do it..
edited
Old Jun 6, 2010 | 05:00 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: 383 tpi
Heh. I topped a mild 383/700R4 combo in my ol' 1990 Vette 'vert with the factory TPI. It may not have been the fastest car around, but boy was it fun to drive. Lurid power-slides were but a stab of the throttle away at any RPM. Buy tires...you'll need 'em.
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
