whats the correct valve cover configuration?
Old Jun 28, 2010 | 08:51 PM
streetworkxs's Avatar
I have an '89 Lb9 305 tpi and am just wondering which is valve cover goes on what side and which way
Old Jun 28, 2010 | 09:21 PM
Re: whats the correct valve cover configuration?
I just need to know if the hole is towards the front or the back on the passenger side valve cover.
Old Jun 28, 2010 | 09:24 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I dont remember which way it goes, but I can tell you they will only go on one way. The bolts are not perfectly centered in the valve cover so the bolts will only line up one way.
Old Jun 28, 2010 | 10:02 PM
puddingmmmmmmmm's Avatar
Car: 05 CTS-V
if your talking about the hole that holds the breather, it's in the back.
Old Jun 28, 2010 | 10:04 PM
thanks guys. got it bolts line up with the breather hole in the back
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 8, 2015 01:18 AM
