problem check engine
Old Jul 19, 2010 | 10:44 PM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
I have an 87 trans am with a 350 tpi and it was rebuild like two. weeks ago. Last week I started to have the check engine turn on n of rigth away. When the check engine turns on the rpms go very high and very low and when I do a turn the car turns off, or when I stop it turns off too, this happends very rearely not always. I took the car to the mechanic but everytime I take the car with the mechanic the check engine light is off so he can't check it. Thanx.
Oh and this happnes when the car is hot
Old Jul 20, 2010 | 08:14 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: problem check engine
have you ckd. the codes ? they will be held untill re-set . checking codes will put you on the right track . good luck .
Old Jul 20, 2010 | 08:25 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
short out
[ ] [ ] [ ] [ ] [b] [A]
your Ecu will flash 1 - 2 Four times = Code 12 system is OK
anything after Example 2 - 5 = Code 25
Old Jul 20, 2010 | 10:15 AM
jll87TA's Avatar
Axle/Gears: stock
Ok so even if the check engine is off I can still check it?
Old Jul 20, 2010 | 10:18 AM
jll87TA's Avatar
Axle/Gears: stock
Originally Posted by 88gta3508
short out
When I'm turning on my car it flashes 1 or 2 times
Old Jul 20, 2010 | 11:40 AM
88gta3508's Avatar
Engine: 231 / 383
your CE light will blink one flash = #1 then two flashes = #2 <> = 12 this will happen 4 times... this is normal....
if you do not get any other code.. your system has no detectable problems...
if you pulled your battery... you will need to run your car for a while.. to store any faults or codes
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
