return to returnless fuel system conversion
Old Aug 27, 2010 | 02:58 AM
ace69247no13's Avatar
Car: 1991 z28
Engine: 350 .060 over 400 crank, 12:1
Transmission: t5
Axle/Gears: 2.73 currently
has anyone done the conversion? if so help i need info
Old Aug 27, 2010 | 03:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: return to returnless fuel system conversion
How " returnless " is it ?
Are you putting a regulator by the tank and dead heading to the fuel rails?
Old Aug 27, 2010 | 05:32 AM
Car: 1991 z28
Transmission: t5
well i would like to go completely returnless so regulator in or near the tank and yes as you say dead heading the fuel rails
Old Aug 27, 2010 | 09:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What would be the advantage?
Old Aug 27, 2010 | 10:16 AM
Car: 1991 z28
Transmission: t5
i want to do this to stop heating the fuel up so much by recirculating from the engine compartment
Old Aug 27, 2010 | 10:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
So instead you're going to have it sitting still inside the lines in the engine compartment for logner?
Old Aug 27, 2010 | 10:51 AM
Car: 1991 z28
Transmission: t5
not really and the thing i am trying to stop is not the heated fuel in the lines in the engine compartment but the superheated fuel in the tank
Old Aug 27, 2010 | 10:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why is it getting superheated in the tank?
Old Aug 27, 2010 | 10:59 AM
Car: 1991 z28
Transmission: t5
your guess is as good as mine. i have been having the problem ever since i put the engine back in. the car sat parked for three years without an engine. it did not have the issue it is having now before it was parked nothing changed since it got parked. same engine same exhaust everything
Old Aug 27, 2010 | 11:06 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I've always been under the assumption that a return style fuel system is cooler due to the fuel always moving around and not sitting still. Do you have the heat shield between your muffler and fuel tank? What do you mean by superheated? Have you measured the temperature?
Old Aug 27, 2010 | 11:10 AM
Car: 1991 z28
Transmission: t5
yes the heat shield is there. and like i said nothing has changed since before the car sat for three years, and it did not have a problem before it sat. by superheated i just mean a hell of alot hotter than it should be, hot enough to cause the engine to stall and fuel pump to groan
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
