How much HP!
Old Sep 9, 2010 | 02:02 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
How much HP!
How much hp can I get if I get these parts?:
edlebrock headers
slp tpi airfoil
edelbrock high flow tpi manifold with runners (kit)
BBk throttle body 52mm
throttle body spacers
gmmg exhaust.
Old Sep 9, 2010 | 02:20 PM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
Re: How much HP!
Heres a lil break down
edlebrock headers
slp tpi airfoil USELESS
BBk throttle body 52mm USELESS
throttle body spacers USELESS
gmmg exhaust.
The throttle body wont help you except if your pushing big power. Port your stocker if anything.
Headers with good exhaust ~15-25hp
runners will get you 10-15hp as well but port match the upper plenum to match
Save your money and leave the airfoil tb spacer and throttle body off the list
Old Sep 9, 2010 | 02:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: How much HP!
On motor in the sig? 305?
Agree with the above. Full exhaust which is catback/headers/ypipe is good for 20-25hp on most setups. manifold+runners will show a good gain, 10-15 hp but extend the rpm range a tad, especially if you siamese them abit. Bump base timing up from 6 to 8-10 and it should do well.
Old Sep 9, 2010 | 02:46 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: How much HP!
BBK <<< and almost all after market TB already have the foil built into them
Old Sep 10, 2010 | 10:01 AM
pestrada38's Avatar
Re: How much HP!
Then if I add a cam will that make a big deference? I been told my stock cam is the best I can do because my car came with the option of 3:42 gears with a 5 speed with a hurst shifter, ws6, dual cats, and disc brakes. Cars that came with this option had a bigger cam than most 305's. Automatics had a smaller cam. If this is true, am I stock with this cam or can i get a bigger cam. If I replace my stock rockers does it increase HP?
Old Sep 10, 2010 | 10:14 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: How much HP!
You can still change to a different cam and see a power gain. You would gain power by switching to a roller rocker with a higher ratio, but the gain wouldn't be that big.
Old Sep 10, 2010 | 10:23 AM
88gta3508's Avatar
Engine: 231 / 383
Re: How much HP!
you would need to select a cam.. for a specific goal!!!!!
if your looking looking to increase 100 HP or so...
after market heads... should be on your list. your current 305 heads have smaller valves
and would require... porting, valves, guides springs, seals... your in the range of after market.. cam + compression + flow will give you results..
rockers on your stock cam will not not produce much at all..
what is your current goal with your car.....
Old Sep 10, 2010 | 11:17 AM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Re: How much HP!
another good mod for seat in your pants that aint too expensive is 1.6 rockers wake that cam up a lil bit
Old Sep 10, 2010 | 03:07 PM
pestrada38's Avatar
Re: How much HP!
My goal is to make some good horse power without messing up the computer.
Old Sep 10, 2010 | 06:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: How much HP!
Computer should be tuned for all the mods in the end, you can gain some hp with minor changes to the stock chip on even a bolt on motor. A cammed setup should get retuned.
1.6's seemed to make a difference on my L98. I dyno'd with air fuel in the 12.5-12.6 range but after the 1.6's and few other minor things in colder air, I dyno'd only 8 more hp but air fuel was 14.2-14.3... so I wonder if that setup went super lean with the extra fuel? I did change injectors so maybe the spray pattern was different. With same air fuel I would have expected a much better gain in hp
Old Sep 10, 2010 | 06:52 PM
Re: How much HP!
when i put on my 1.6 rockers my o2 sensor kept runnin lean poppin the code until i got an afpr bumped up the psi a lil no code or problems ever since
