TPI WIRING HARNESS
Old Oct 17, 2010 | 08:23 PM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
TPI WIRING HARNESS
can a tpi harness and computer for a 700r4 with electric speed sensor work with a t5 with manual speed sensor i have two camaros one i already bought all the tpi for the 350 tuned port and i was wondering if i needed to buy a painless or could i use the wiring harness i already have i dont need the car its in any ideals
Old Oct 17, 2010 | 09:17 PM
Damon's Avatar
Re: TPI WIRING HARNESS
Having never done that exact swap I can't say for sure. Certainly an auto trans car setup is going to have one more hookup that you won't have with a manual- the torque converter lockup.
I suspect that the T5 with a cable (assuming that's what you mean) isn't going to work with an ECM designed to work with a trans (any trans) that's designed to have a direct link to a VSS in the tailshaft, but I would wait to see what othrs have to say on the subject.
Old Oct 17, 2010 | 11:24 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
vss is a manual cable running to the back of the gauge but i dont know about if it will be the same harness
Old Oct 18, 2010 | 07:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Damon
I suspect that the T5 with a cable isn't going to work with an ECM designed to work with a trans that's designed to have a direct link to a VSS in the tailshaft,
If a T700 VSS won't fit in the T5 you need one of these ( depends on what year ECM you are using; different signals ) to give the correct VSS signal to the computer .
Just connect to the purple and yellow wires on the TPI harness that went to the auto VSS
http://cgi.ebay.com/ebaymotors/85-89...Q5fAccessories
http://cgi.ebay.com/ebaymotors/90-92...Q5fAccessories
The 4 pin plug on the TPI harness that went to auto for convertor lockup you don't use on a manual
Old Oct 18, 2010 | 11:36 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
http://www.jagsthatrun.com/SpeedSensors_Order.html
This might help also.
Old Nov 9, 2010 | 12:28 AM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
but i would buy the right chip and everything what i was wondering if i did that and manual ran the vss with the manual cable aready on the car if it would work?
Old Nov 9, 2010 | 07:30 AM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
I've used the speed sensor/gear drive type sensor for 90-92 Camaro/Caprice patrol car in at least half dozen TPI streetrod type installations. It has the VSS plug to go to ECM and also used a cabel drive for older speedos. Works great.
The 67 Firebird vert in sig is using that setup.
I can get you a Delco part number when I get home if you need it.
Standard, I believe makes the same part as the Delco unit.
Old Nov 10, 2010 | 01:03 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
the cars speed sensor is a manual cable dont have the vss sensor on the tail shaft the only connector in the t5 is the reverse and shift light i dont need the shift light all i need is the reverse light thats why i thought is i used the auto harness i would only use the reverse light connector and nothing else looks like it would work but i wanted to make sure before i yank it all out
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
