IDLING FEELS ROUGH ABOUT EVERY TWO SECONDS
Old Oct 17, 2010 | 09:26 PM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
well when my 1989 CHEV CAMARO IROC-Z is idling or even when you rev the engine you feel like a roughspot then goes away then again and so on its there all the time i was wondering if i can get some tips on what it might be
Old Oct 21, 2010 | 07:19 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: IDLING FEELS ROUGH ABOUT EVERY TWO SECONDS
Are you running an aftermarket chip. Hypertech, etc? If you have modified the car in any way it wont run right
Old Nov 1, 2010 | 03:09 PM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
nope stock
Old Nov 4, 2010 | 08:33 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I had/have a similar problem. Through process of elimination, I have decided its probably the injectors. Let the car warm up then turn it off and ohm the injectors hot. If your numbers aren't in the 15-16ohm range you know you have bad injectors.
Just fyi my injectors ohmed out well, but they dont spray well which has given me problems. so what im saying is even if they ohm out well, they still could be contributing to your problem.
Good luck!
Old Nov 6, 2010 | 07:57 PM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
thanks i was looking at my harmonic balancer and the ring around in one spot it seems to be popped out i also have another question im trying to buy copper head gaskets but its asking me for bore and thickness would you what i have to do to know all that to buy the proper one thanks
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
