Injector help
Old Oct 24, 2010 | 01:17 PM
jak's Avatar
jak
Injector help
Hey all, Im new to the tpi game .. I recently bought an 89 gta 5.7 liter..From reading other posts i know you guys want details on the engine to help me along...Which by the way i greatly appreciate..ok here goes
89 5.7 tpi
Has been rebuilt with eagle rods, eagle crank ,eagle pistons ,moly rings , crane cam (2032) msd distributor, msd coil, tps airfoil( not sure what this is) , AFPR running 50 lbs of fuel pressure, underdrive pulley kit, edelbrock headers, high flow y pipe, borla adjustable cat back exhaust.. Hpertech comp with 160* thermostat
Ok i think i may need injectors i am getting ready to test them..My question is if i do need injectors should i go to 27lbs or stay with the 22lb..I do not plan on making any more mods to the car.. Other than an idling issue it runs good..
Thanks in advance
Old Oct 24, 2010 | 02:07 PM
southbay08's Avatar
Re: Injector help
need a little more info, after all of these mods what kind of horsepower are you planning to run? And why 50psi?
Old Oct 24, 2010 | 03:40 PM
jak's Avatar
jak
Re: Injector help
Hi Southbay not going to make anymore mods than what it currently has, im assuming somewhere around 300 hp at the flywheel is what this combo runs give or take 10 ..This would be my estimate ..As far as the 50 psi i did not set this there ..the previous owner made all the mods and set the fuel pressure at this...He never played with the injectors though..As i assumed #1 injector ohms out at 9.2 the rest even across the board at 16.3..Im not sure but once again i assmued the 50 psi was what crane wanted as far as the cam he put in but once again im guessing
Old Oct 24, 2010 | 04:04 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: Injector help
Try Jon at www.fuelinjectorconnection.com he can help you out!
Old Oct 24, 2010 | 04:42 PM
jak's Avatar
jak
Re: Injector help
um gee thanks but i was kind of looking for help texas not a salespitch for your buddies website
Old Oct 24, 2010 | 05:03 PM
texascat2's Avatar
Re: Injector help
Well, he's not a buddy and it wasn't a sales pitch, just offering an avenue to help you. I guess you have it figured out so disregard any posting from me.
Old Oct 24, 2010 | 05:15 PM
jak's Avatar
jak
Re: Injector help
Well in that case i apologize i made an assumption by reading your sig..I did go to the website but i didnt seem to user friendly to me other than having decent prices...
Old Oct 24, 2010 | 06:42 PM
InjectorsPlus's Avatar
Former Sponsor
Re: Injector help
89 5.7 tpi
ok
Has been rebuilt with eagle rods, eagle crank ,eagle pistons ,moly rings , crane cam, (specs on cam are, intake at cam 301 exhaust 310...intake at valves 452 exhaust 465) msd distributor, msd coil, tps airfoil( not sure what this is) , AFPR running 50 lbs of fuel pressure, underdrive pulley kit, edelbrock headers, high flow y pipe, borla adjustable cat back exhaust.. Hpertech comp with 160* thermostat
The ONLY mod you have listed here that does ANYTHING to increase the power of the car is the cam.
The rest contributes nothing and you don't need new injectors based on that.
HOWEVER, the cam specs are all over the place. 301 DURATION? REALLY?
You need to have the car tuned to match the cam, and that will determine the injectors.
Thanks in advance
STOP. before you go buying injectors let's figure out what you are doing. You're going to require a tune, not an off the shelf chip. OF the mods you listed, none of them add any power to the car and the cam specs are all off or that's one huge cam for a small block 350.
What you NEED is figure out what you're doing, what you have, before we start talking injector sizing.
Again, call me maybe we can figure this out.
Honestly, I wouldn't sell you injectors at this juncture because we don't have a complete picture, we'd never get it right. Running off the shelf calculators isn't going to help until you figure the rest out.
Old Oct 24, 2010 | 06:46 PM
southbay08's Avatar
Re: Injector help
pm sent
Old Oct 24, 2010 | 07:33 PM
jak's Avatar
jak
Re: Injector help
For those just reading i modified the original post as the cam specs are wrong.. looks like the 22lb will work well..
Old Oct 24, 2010 | 07:57 PM
Former Sponsor
Re: Injector help
As per our PMs, here's the link to your cam:
http://crane.carshopinc.com/product_...d/15861/104224
Check if it's REALLY a 350 as this cam is spec'd for a 305 and will act as a smaller cam in a 350, and it's not that big to begin with.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
