What year is this engine (pics)
Old Oct 25, 2010 | 05:17 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I called the guy but he has no idea what year the engine is from. Hell of a deal.
http://sandiego.craigslist.org/csd/pts/2023003141.html
Old Oct 25, 2010 | 05:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What year is this engine (pics)
86-88
Old Oct 25, 2010 | 05:23 PM
Twin_Turbo's Avatar
Looks like a 87-88 1 pc rear main casting that can accept a factory roller cam: taller lifter bores & machined for flat surface to rest dog bone on but not drilled for spider plate, easy to do. probably something out of a truck or whatever. Cheap indeed.
Old Oct 25, 2010 | 05:32 PM
Car: 89 GTA
Axle/Gears: 4.10
So the truck engines had solid lifters? I checked the casting # and it is indeed from a truck.
Old Oct 25, 2010 | 05:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, solid lifters in trucks, and often the blocks weren't fully machined for the factory roller set up, like that block.
Old Oct 25, 2010 | 10:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Hyd flat tappet , not solid lifters
Old Oct 25, 2010 | 11:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oops, I meant flat, not solid.
Old Oct 26, 2010 | 10:30 AM
Car: 89 GTA
Axle/Gears: 4.10
So what needs to be done to the block besides adding a spider plate to run a roller cam and lifters in it?
Anything else that is different about this engine for me to run it in my 87 TA?
Old Oct 26, 2010 | 09:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It needs a cam retainer in the front, and a set of dogbones, and you'll have to drill and tap the bosses to bolt down the spider. Externally it's identical to what came in your 87.
Old Oct 26, 2010 | 11:20 PM
Guest
Guest
Posts: n/a
Looks like a mix and match to me. Those are not centerbolt heads, but it looks like it has self aligning rockers. And I'm only seeing one accessory bolt hole in the passenger head. FYI.
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
