SD TPI stumbling/hesitation in open loop
Old Oct 30, 2010 | 06:45 PM
QUICK305's Avatar
Have a 90 L98 with new plugs, wires, cap, rotor, ignition module, coil, fuel filter and FIC Bosch injectors. Was previously chasing a stumbling/part throttle hesitation in closed loop which has since resolved with the replacement of the above components. However, I am still faced with a part throttle hesitation in open loop when the car is cold. For the most part, the car runs well in closed loop once warmed up.
Any suggestions? Haven't checked the fuel pressure at the rail yet...
Old Oct 31, 2010 | 09:19 AM
QUICK305's Avatar
Re: SD TPI stumbling/hesitation in open loop
Forgot to mention, TPS reading looks ok in Diacom.
Lots of threads here about these type of issues in closed loop, but not open. Searched w/out success.
Old Nov 8, 2010 | 10:07 PM
QUICK305's Avatar
Any ideas? Now that the weather has gotten cooler, this is very noticeable.
I am now finding this issue has returned (although significantly milder) once the car is warmed up and in closed loop. Fresh out of ideas
Old Nov 9, 2010 | 10:58 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Try a new O2 sensor. Mine did the same crazy stuff From being rich.
Old Nov 10, 2010 | 08:43 PM
QUICK305's Avatar
O2 sensor is new and was replaced with the addition of the headers. Readings look good in Diacom
Old Apr 7, 2011 | 10:07 PM
QUICK305's Avatar
Still having issues with sputtering and power loss in open loop. Car feels like it hits walls at certain RPMs and is way down on power. I have also replaced the CTS which did not seem to help this problem.
Once the car reaches closed loop and is up to temperature, drivability improves greatly.
At this point , I feel that possible causes could be a vacuum leak or bad EGR. I also plan on getting a fuel pressure guage just to rule out any fueling issues (although I would think a fueling issue would be present in both open and closed loop).
Any ideas?
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
