Engine stalls while driving ................
Old Dec 8, 2010 | 12:24 AM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
My 1987 trans am has been stalling out while driving. I have the 350 TPI in it and it's a weird issue. I'll be driving and the motor just quits on me and after about 30 seconds or so it lights back off as i am coasting. It has started doing this since it got cold.... I havnt ran the codes on it yet. But it fires right up if it doesnt light off from coasting. Any thoughts or ideas what I should be looking at???
Old Dec 8, 2010 | 09:31 PM
Beggins's Avatar
Engine: 355 TPI
Re: Engine stalls while driving ................
Ran codes got nothing .........
Old Dec 8, 2010 | 11:59 PM
jak's Avatar
jak
Interesting i would start the car up and do a wiggle test on the ecm wiring..Also would do that at my connectors on the dizzy..A wiggle test is just what it sounds like..Grab the wires and wiggle them see if it stalls..If it does then isolate the wire and repair..
Old Dec 12, 2010 | 08:52 PM
Beggins's Avatar
Engine: 355 TPI
Screw it I'm going carburated
Old Dec 13, 2010 | 03:19 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Did you check for fuel pressure? A clogged filter or a dying pump will do it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
