Underdrive pullies????
Old Dec 19, 2010 | 09:54 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I know they don't help much but they are alittle lighter so that helps, the car does have a stereo in it sO I don't want the volts to be messed up. Should I go 3 or 2 piece? Also march sells a performance one and power and amp series. What's the difference? What will keep correct voltage? I know jet, BBK also make some.
Old Dec 20, 2010 | 05:16 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Re: Underdrive pullies????
i got March 4445's power and amp series , they work wonderful,no voltage problems at all ! get the 4445's or the black ones and you'll be pretty happy
Old Dec 20, 2010 | 05:43 PM
Axle/Gears: G92
Thanks for the info, I've been looking into them and worried that voltage would mess up and having the stereo doesn't help.
Old Dec 20, 2010 | 05:54 PM
Calderone's Avatar
Car: 87 Vette
You're welcome,now the alt its steady at 14.3v, it never goes down or up.
and the looks of it its killer !!!
Old Dec 20, 2010 | 06:03 PM
Axle/Gears: G92
Cool, I can't even find info on the other pullies or reviews at all.
Old Dec 20, 2010 | 06:05 PM
Calderone's Avatar
Car: 87 Vette
Don't bother, i did a big research and got what i found it was best.
I was right,March Pulleys Power&Amp delivers !
Old Dec 20, 2010 | 06:14 PM
Axle/Gears: G92
Is yours the 3 peice or 2 piece?
Old Dec 20, 2010 | 06:16 PM
Axle/Gears: G92
http://www.summitracing.com/parts/MCH-4445/
That part number is the corvette ones?
Old Dec 20, 2010 | 06:19 PM
Calderone's Avatar
Car: 87 Vette
Im sorry , yes i have a 87 Corvette, but im sure you can find the ones for your car.
its the 3 piece set
Old Dec 20, 2010 | 06:25 PM
Axle/Gears: G92
Ok thanks for your help!
Old Dec 20, 2010 | 06:27 PM
Axle/Gears: G92
Anyone know what the belt size will be?
Old Dec 20, 2010 | 08:52 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I ran the non-power amp pullies and had a lot of problems with them. Voltage dropped way low at idle. Had to take them off.
Old Dec 20, 2010 | 08:55 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
if running the 2 piece instead of the 3 will the volts still drop and possibly run hotter?
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bryaniskoo
Oct 1, 2015 03:18 PM
italiano67
Sep 22, 2015 08:42 AM
Navy8125
Aug 22, 2015 07:13 PM
