383 Tpi
Old Jan 13, 2011 | 12:53 AM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Transmission: 4 speed auto
Axle/Gears: stock
383 Tpi
Ok I have a 383 Stroker tpi in my 87 vette. Im running stock Intake no porting. LT4 Hotcam, 1.6 RR, longtube headers, Borla Exhaust, and 24lb Bosch Injectors, Stock heads, and the stock computer chip
I bought 30 lb bosch Injectors because every one said the 24lb are to small. not installed
The car feels like It doesn't have power at the top end (3500-5000)
I keep reading Its the intake that is restricting me. If it is I was thnking of going with a used Accel Super Ram kit.
I was going to buy a chip from pcm when Im finshed.
Let me know what you think and your advice on my situation
Old Jan 13, 2011 | 04:21 AM
jim_in_dorris's Avatar
Re: 383 Tpi
What is holding you up is not the injectors or the intake at this point, it's the tune. 24# injectors should be good for about ~360 hp which is the most your setup will make. yes the heads and intake run out of breath after 5000 rpm, but you are having problems in the 3500-5000 rpm range, My guess is your tune. Data log your engine, I would imagine that from 3500 to 5000 rpm you will need to add both fuel and spark advance. What engine did your vette start out with? a 350? Adding displacement and a cam will drastically change the requirements for fuel and spark.
Old Jan 13, 2011 | 05:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 Tpi
TPI on a 350 maxes out below 5k ( will rev higher but doesn't make any more power ) so will max out lower on a 383
383 with stock TPI ( but with big heads and cam )
it's the tune. you will need to add both fuel and spark advance.
FWIW
I ran a ported TPI on the 383 in my '87 Vette with close to stock tune; only adjustment was for larger injectors
Ran 12.7
Swapping to a HSR intake with no other changes got 12.3 1st time out
Old Jan 13, 2011 | 11:29 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
Re: 383 Tpi
Bought the Accel Super Ram to day $400
Old Jan 13, 2011 | 11:51 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: 383 Tpi
nice find man
Old Jan 14, 2011 | 08:02 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 383 Tpi
its a combo of the intake and a tune...put that super ram on there and get a dyno tune and you will be in good shape
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
