flat tappet or roller ???
Old Jan 19, 2011 | 08:21 PM
ray jr's Avatar
im redoing a 86 40k iroc that i bought in october ...complete paint job and im also going to give it somemore horsepower .. the motor runs great so i dont have to pull it and go through it ... so far ive put in a new 255 fuel pump,3.42 gears with a eaton posi,3 inch exhaust and magnaflow convertor, ive gathered hooker 2055's headers, tpi ported big mouth lower intake,big tube runners,ported plenum.. im going to order tfs 56cc aluminum heads for it but i cant decide on what camshaft to go with ..
my main question is what would it take to put a roller cam in my non roller block ? the cam im thinking about is the comp. 08-501-8 which is the xr-264-12.. or should i just put a flat tappet in and call it a day ?? thanks for any input from the cam guru's or guys that have done this before ..
Old Jan 19, 2011 | 08:35 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: flat tappet or roller ???
you'll need retro fit roller lifters and a roller cam, also will need shorter push rods being the lifters are longer
Old Jan 19, 2011 | 10:00 PM
F-Body Demon's Avatar
Do yourself a favor and put in the best cam you can. Now maybe the only chance you get!
Old Jan 19, 2011 | 10:14 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You'll need a cam button to control end-play at the front of the cam, and possibly a different distributor gear, depending on your cam choice.
As was already said you'll need the retro-fit roller lifters with the link-bars, and shorter push-rods.
The cam in my signature was designed by LPE to go into 305 TPI builds.
Old Jan 19, 2011 | 10:15 PM
ray jr's Avatar
so besides the roller cam what needs to be bought to convert to a roller setup for my non roller block ? i know lifters etc.. but which parts am i looking at ?? brand or maybe a part number ..
Old Jan 19, 2011 | 11:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.summitracing.com/search/P...=roller+lifter
Roller cam pushrods are 7.200" long but actual length needed should be checked before buying.
http://www.summitracing.com/search/P...yword=pushrods
http://www.summitracing.com/search/P...n&Ns=Price|Asc
Old Jan 19, 2011 | 11:11 PM
ray jr's Avatar
so besides the cost its a pretty easy deal to setup ??
Old Jan 22, 2011 | 11:56 AM
ray jr's Avatar
i went on comp cams sight to look at roller cams and they list retro fit hyd. roller cams and regular hyd. roller cams ... whats the difference ?? im looking at the xtreme energy xr264hr cam ..one part# is 12-412-8 for retrofit and the other is 8-412-8 ... same price and they look like the same cam ..
Old Jan 22, 2011 | 01:31 PM
Car: 89 Formula 350
retro fit lifters have a link bar to keep them aligned..so ull need the 853-16 or the 885-16 lifters for a retro fit engine. The 12-412-8 is the retro fit version of the XR264HR...The 8-412-8 is the version of the same cam for engines that came from the factory as a roller motor.
Old Jan 22, 2011 | 07:57 PM
ray jr's Avatar
im going to go with the howards retrofit lifters .. out of the 2 xr264 cams i listed will one work in my 86 305 and one not ? i still dont understand the difference in the 2 cams ..
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
