tpi throttle body
Old Jan 24, 2011 | 01:49 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
tpi throttle body
question.....yes I have searched, either using wrong words or just can't find what I'm looking for.
this is a 90 sd----the port on the pass side top......what does that go to, and can it be left open, could this cause a miss at idle?
I've seen on some post it goes toa CCV but I also only found this on 86 and older.
and if you have apic that would be awesome.
thanks
Old Jan 24, 2011 | 02:27 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: tpi throttle body
As set up from the factory that port is for CCV from the PS valve cover. If you're not using it definitely cap it off.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
