help with checking vacuum
Old Jan 25, 2011 | 10:44 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
some help is needed guys
I have a 90 350 tpi and it sounds like a miss at idle.
so I would like to check for vacuum leaks, where is a good place to check from. this motor does have the canister anymore did not come with one.
The only place I can think of is the port on the plenum rear pass side
and what reading would I be looking for.
Old Jan 25, 2011 | 07:08 PM
gscz28's Avatar
Car: 89 iroc
Re: help with checking vacuum
ttt
can't believe someone doesn't know where to check vaccuum at
come on guy's don't let me down
Old Jan 25, 2011 | 07:47 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
try spraying some starter fluid/carb cleaner between the lower intake and heads, also between the lower intake and runners and between the runners and pleanum.Between the pleanum and TB.. Look anywhere in the intake that it comes apart. Might also want to check to see if the injector O rings have a vacuum leak. Idle should race up if you spray an area that has a leak. If you have an AF gauge you will go from lean to rich. Make sure you cap off any open unused vacuum lines... Good luck
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
