87 TPI 350 dies while driving........
Old Jan 25, 2011 | 07:37 PM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
My Trans Am dies while i am driving doesnt matter whether i am in throttle or out of it. It dies unexpectedly gives no indications or noises just dies. Car restarts fine. eith by putting it in neutral or park. I get no codes from the computer. It's got me baffled as to what causes it. Please help... gotta get the car ready for a cross country move.
Old Jan 26, 2011 | 05:54 AM
Beggins's Avatar
Engine: 355 TPI
Re: 87 TPI 350 dies while driving........
Help someone any one ???
Old Jan 30, 2011 | 06:27 AM
malibuz16's Avatar
I would check either the coil or the ignition module.
Old Jan 30, 2011 | 07:34 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Could be fuel pump? Check to see if you're getting fuel
Old Jan 30, 2011 | 01:42 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
my module did that.
Old Jan 30, 2011 | 03:57 PM
Beggins's Avatar
Engine: 355 TPI
Found part of the Problem... IAC motor was messed up..... still abruptly dying just not as often....
Old Aug 15, 2012 | 11:41 PM
Beggins's Avatar
Engine: 355 TPI
found out why the car was dying... coil had a bad ground.....
Wade787b
Sep 29, 2015 01:15 PM
Out-Cast
Aug 17, 2015 10:57 AM
bamaboy0323
Aug 15, 2015 07:20 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
