LT1 Cam with 1.6 Roller Rockers
Old Feb 2, 2011 | 03:03 PM
vette_1989's Avatar
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
I have a 1987 Camaro with a stock 305 V-8, except for a LT1 cam. I would like to install 1.6 roller rockers, but would these exceed my limits of my stock valve springs?
Old Feb 2, 2011 | 05:56 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: LT1 Cam with 1.6 Roller Rockers
yes
Old Feb 8, 2011 | 07:12 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Swap in some ZZ4 springs, locks and retainers.
Pretty cheap GMPP parts.
Old Feb 8, 2011 | 10:00 PM
vette_1989's Avatar
To use the ZZ4 springs, do I have to machine the heads for these to fit?
Old Feb 8, 2011 | 10:32 PM
Car: 89 IROC
Nope. I run an LT1 cam with ZZ4 springs and a 1.5 rocker on my 305 but it will take a 1.6 with no problem.
Old Feb 8, 2011 | 10:47 PM
vette_1989's Avatar
Where did you purchase your ZZ4 springs? Did you remember the cost? How do you like your LT1 cam with your 305?
Old Feb 8, 2011 | 11:32 PM
Car: 89 IROC
I picked up the ZZ4 springs, locks and retainers from GMpartsdirect.com. I was working in the US at the time and had everything shipped to the hotel. I believe I paid under $100 for everything 3 years ago.
Springs - 12495494
Locks - 12495503
Retainers - 19171528
The LT1 cam is a good upgrade from stock and adds about 25 hp. I also have Edelbrock ceramic headers, a 4th gen alum. driveshaft, dual cats and 3" exhaust with an SLP muffler. The motor sounds very nice. Need to get it on a dyno this year and pull some numbers. I'm guessing around 210 to the wheel.
I also have a new ZZ4 cam waiting to go in...just need to save up for some Trick Flow 305 heads
Old Feb 9, 2011 | 06:46 AM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Misread op.
Last edited by Rod Behring; Feb 9, 2011 at 06:53 AM. Reason: misread original post
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
