motor wants to stall when at a stop?
Old Apr 7, 2011 | 12:21 PM
  #151
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: motor wants to stall when at a stop?
It's Mikey, I'm sorry. i haven't been very thoughtful on helping you with this issue. We started by looking for a wiring issue, then went to the ECM, now were looking at bad sensors and I haven't been giving you very good guidance. I never even mentioned using a scan tool to verify what is actually happening when this problem occurs. This is generally the first think I suggest. Why I have not guided you back to testing I don't know. Sometimes we get so lost in the forest, we can no longer see the trees.
You are getting to a place where you are putting alot of money into this problem. I would like to see you step back and take a deeper look at what is causing this issue. There are several types and brands of scanners available that will read your ECM. Tuner Pro is a PC based system that has many capabilities, including data acquisition and recording. You cvan do a Google search to find where to buy it. Another option is a generic scan tool. I just used my old Snap On MT2500 "Brick" yesterday diagnosing a 93 Olds. The "Brick" was the tool to have 20 years ago. They sold for $2,500 new. Now I see them floating around for $300. Most Techs wont bother with them because all of the scanning capability of the MT2500 is available in either of the newer and much cooler Snap On machines. But for $300, they're a great value for the DIYer. And they will work on many vehicles, including OBDII even Europian and Asian with the right software. And over several model years.
Get a scan tool of some kind that will read OBDI GM. Use it to look for any clue as to what is causing your system to behave the way it is. Every component I can think of that should cause this poroblem has been replaced. We need to look at the system as the ECM sees it to see what is out of place. This will point to wiring or other issues in some part of the system that's causing this set of symptoms.
Old Apr 8, 2011 | 03:37 PM
  #152
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so i ended up taking it back to the shop...they couldnt get the new ecm to communicate with there scanning tools, so i took the stock ecm back and its running great.
the maf, was in fact, bad. but since the ecm wasnt compatible, it showed no change to me.
in the end:
bad mass air flow sensor (maf)
dirty idle air control (iac)
HUGE vaccum leaks
big thanks ASE Doc and everyone else that contributed to helping me
Old Apr 8, 2011 | 05:46 PM
  #153
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
This is one more of several cases where I've seen ECMs replaced due to misdiagnosis. Don't feel bad. I've done it myself with some fairly expensive units, like the ABS module in a 2004 F-250 Ford P/U. $650 and alot of hair pulling later, I found a shorted connector in the harness. BTW, once powered up, or in some cases once the sealed package is opened, ECMs are not returnable. This is one more painful reminder to us all to think twice or even three times before replacing an ECM.
  #154
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Good job Mikey, and happy motoring!
Old Apr 8, 2011 | 07:46 PM
  #155
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Congrats! Back on the road and 1 day closer to an LS1 swap during a BBQ wink wink. lol!
Old Apr 8, 2011 | 11:44 PM
  #156
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks
it was a used one but yeah, i tend to jump and just start changing stuff...
shhhh...you might upset the trolls
Old Apr 14, 2011 | 09:29 PM
  #157
itsMikey's Avatar
Engine: 5.7 350 TPI
aaaaaaallllllrrrriiighhttttt -__-
so its doing it YET AGAIN!
now tho...ive replaced
the fan switch (drivers side head)
alternator
coolant temp switch
the codes still wont flash...not even the 12 that its supposed to.
when i turn the igniton ON the primary (drivers side) fan comes on and the ses light stays on and stays solid.
when it was running (without ses light on) the ses light would blink twice on igniton then stay on until i started the car and it ran great.
blows my mind...its gotta be the ECM right??
i think tpis sent me either a bad ECM or a non-compatible one. sent it back already.
HALP?? lol
Old Apr 14, 2011 | 11:36 PM
  #158
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
Re: motor wants to stall when at a stop? (vacuum leak-dirty iac-bad maf)
sux man...i had mine in the shop and had injectors replaced and cts replaced,tps set,iac replaced...worked great for about a day now i think the fuel pump is shot but idk ive discovered too many to count bad grounds and i am not financially able to keep up with it im gonna see if the fuel pump does the trick and get a new fuel filter...im also gonna go to a jy and replace ecm in hopes there is an issue in there
Old Apr 15, 2011 | 12:31 AM
  #159
itsMikey's Avatar
Engine: 5.7 350 TPI
mines gotta be the ecm cuz i cant even attempt to pull codes.. >.<
Old Apr 18, 2011 | 04:54 AM
  #160
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
wow, it sounds like you both are having a huge amount of problems here, if you find out let me know cause my 86 L98 camaro vert is doing the same thing
Old Apr 18, 2011 | 10:10 AM
  #161
itsMikey's Avatar
Engine: 5.7 350 TPI
put a new ecm in and its running great (for now) will let u guys know
Old Apr 18, 2011 | 10:15 AM
  #162
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh man! I dropped this thread because I thought you were all done fixing this car?! I hope it's all good now.
Old Apr 18, 2011 | 11:33 AM
  #163
itsMikey's Avatar
Engine: 5.7 350 TPI
it seems to be atm haha..the ses light still blinks when i turn the ignition on tho..made a new thread for that...
Old Apr 18, 2011 | 07:04 PM
  #164
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Wow, I had a season that sounded a lot like this, but injectors finally resolved it, sounds like you've been down that road already and it sounds like you've got a lot more going on...
I hope the new ECM helps, if you still have problems, you need to start going through wiring, maybe a mouse made shop under the hood somewhere and went to work... I had a nest right on top of the intake, under the plenum (made a nice little home), and they made my injector harness a main course. Those little f'ers can make one heck of an electrical nightmare. You may want to pull your passenger side inner fender to get access to the ECM harness inside the fender and make sure it looks OK. I believe the ECM harness also winds up by the blower motor (which will make a nice little rodent home too).
Old Apr 18, 2011 | 10:30 PM
  #165
itsMikey's Avatar
Engine: 5.7 350 TPI
i doubt theres any rodents in there..the cars daily driven
i need to know what the flashing ses means!!! ahhhhh!! haha
Old Apr 18, 2011 | 11:04 PM
  #166
itsMikey's Avatar
Engine: 5.7 350 TPI
uhhh sooo wtf is this??? O.o and how come it doesnt go to anything?
Old Apr 18, 2011 | 11:48 PM
  #167
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
thats your vapor canister and it should hook up to a metal line from the tank.....
Old Apr 19, 2011 | 10:06 AM
  #168
itsMikey's Avatar
Engine: 5.7 350 TPI
as in the gas tank? O.o where would the line have gone???
Old Apr 21, 2011 | 08:12 AM
  #169
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Hey Mikey, Look for the metal vapor line to be grouped with the fuel lines as they come up into the engine compartment. The vapor line should end right close to the canister.
Old Apr 21, 2011 | 09:32 AM
  #170
itsMikey's Avatar
Engine: 5.7 350 TPI
got that all hooked back up...
was running good with the new ecm and now its doing the same thing again...
really ready to craigslist it at this point...
ill explain it again...
i turn the ignition on, the ses light comes on, stays solid and the primary fan comes on.
when i start it, it idles weird and when i put it in gear, it wants to stall out and idles really low.
im really at a loss here guys. ive spent so much money and time trying to figure this out
Old Apr 21, 2011 | 09:44 AM
  #171
StrahlZ28's Avatar
Car: 1991 Z/28
Hm... Kinda sounded like an ECM issue... you try replacing the coolant temp sensor?
Old Apr 21, 2011 | 10:07 AM
  #172
itsMikey's Avatar
Engine: 5.7 350 TPI
which ever is the one on the passanger side..i couldnt get too...i think that ones the sensor
i replaced the switch tho (drivers side)
its a brand new ecm...it worked for a week of daily driving..went to go to class earlier and it started doing it again
i was thinking..MAYBE..my aldl plug got messed up in my feeble attempts to get the codes and is grounding itself out? long shot i think tho...
Old Apr 21, 2011 | 10:19 AM
  #173
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The ALDL would be a good place to start. You have an intermittent electrical issue somewhere in the ECM harness. Start wiggling wires.
Old Apr 21, 2011 | 10:33 AM
  #174
itsMikey's Avatar
Engine: 5.7 350 TPI
so start at the ALDL and follow it too the ECM then from the ecm to the engine bay?
just wiggle stuff and see if it changes anything?
this is really starting to stress me out! lol..only stress ive ever had (given, im only 18) has been with this car
Old Apr 21, 2011 | 10:57 AM
  #175
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I know it seems like it's been having issues for a while but I am quite sure that all of this stalling and strangeness is probably due to a single short or open some where in the harness. When you find it, you'll laugh at all the trouble it's caused you.
Old Apr 21, 2011 | 10:59 AM
  #176
itsMikey's Avatar
Engine: 5.7 350 TPI
prolly wanna punch something when i find out its something small
hope thats what it is...im in graphic design right now so thats how im replying but class doesnt end until 2..so ill get on it as soon as i get back home and report back
Old Apr 21, 2011 | 12:13 PM
  #177
Car: 91 formula ws6
Transmission: 4l60E
the coolant temp sensor is on the front of the plenum under the throttle body. the ones on the sides of the head are for the gauge and fan switch. i noticed someone asked you recently in this thread and you said the ones on the sides of the heads. what data is the ect providing? is the booster leaking vacuum when you hit the brakes? just something i wondered yesterday as i read this.
the sensor on the pass head is the fan switch and the one on the drivers side is the gauge sensor
Old Apr 21, 2011 | 01:35 PM
  #178
itsMikey's Avatar
Engine: 5.7 350 TPI
ohh..yeah i replaceed the one on the manifold below the TB too...
its gotta be something grounding out the ecm cuz its like its going into service check mode but not flashing any codes..
gonna check soon
Old Apr 21, 2011 | 03:15 PM
  #179
itsMikey's Avatar
Engine: 5.7 350 TPI
attached a wiring diagram for 5.7 TPI FI for 89 Trans Am (incase anyone else needs it)
Attached Thumbnails motor wants to stall when at a stop?-0900c1528008e89c.gif
Old Apr 22, 2011 | 08:06 AM
  #180
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I am currently uploading diagrams from the Helms factory Service Manual Electrical Diagnosis Suppliment. Unfortunately for your purposes, my book is for the 87 Camaro. The diagrams in the Helms book are very detailed and precise. They show all ground locations and routing. Unlike the pencil drawings that you find on Mitchell. Having really good diagams to work with makes things much easier. I'm assuming you love your TA and plan on keeping it. Look at Helm's webstie for availability of the books for your car. It's a very good investment.
Old Apr 22, 2011 | 11:06 AM
  #181
itsMikey's Avatar
Engine: 5.7 350 TPI
will do i think i got it..the negative battery ground wasnt very tight
Old Apr 24, 2011 | 11:41 AM
  #182
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I was just thinking. I know that sounds dangerous. But your issue could very well be loss of continuous battery power to the ECM. that would explain the lack of DTC memory and the poor idle.
Still, whenever a car runs poorly after its adaptives have been reset, I always watch for Block Learn to go lean or rich and then try to find the cause. In fact, the way an engine runs after reset is one of the indicators I use in verifying proper operation.
Old Apr 24, 2011 | 02:32 PM
  #183
Jpl87t/a's Avatar
H
Hi I have a 87 trans am 305 tpi and I want to ohm check the the injectors. I checked them hot and they read 17 to 18. I also checked them cold and they read 30 to 33. What does that mean? Thanks for the answers in advance!
Old Apr 24, 2011 | 02:36 PM
  #184
Jpl87t/a's Avatar
Injector question
Old Apr 24, 2011 | 05:22 PM
  #185
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Re: Injector question
everybody wants some help on mikeys thread lol
Old Apr 24, 2011 | 06:08 PM
  #186
itsMikey's Avatar
Engine: 5.7 350 TPI
lol..i know
so..guess what guys
it was a bad ground...from the negative cable to the body i couldnt help but to laugh...will admit, was kinda mad too.
Old Apr 24, 2011 | 11:52 PM
  #187
Car: 91 formula ws6
Transmission: 4l60E
ive heard from other owners that that little ground to body wire off the battery terminal can screw up alot of stuff. i have 4 main grounds just in case. might not be a bad idea for the future? i have one to front of block, one to alternator case, one to back of head, and one to trans case. call it over kill but i got excellent ground points when looking.
Old Apr 25, 2011 | 02:52 PM
  #188
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Jpl87, You really need to start your own thread in order to recieve proper attention. 30-33 ohms is way off the charts. I have to wonder if your ohmmeter is functioning properly. Be sure to verify zero with the test leads held together before you test.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
