Proper Timing for 92 camaro 305TPI
Old Mar 10, 2011 | 04:52 PM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
I just need to know the proper timing for a stock 92 camaro 305TPI..the sticker under hood has been removed...thanks
Old Mar 10, 2011 | 05:25 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Proper Timing for 92 camaro 305TPI
IIRC it is 8° or 10° thinking it was 8° and I bumped it up to 10°
Old Mar 10, 2011 | 06:26 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i believe 7 degrees BTDC
Old Mar 10, 2011 | 06:32 PM
I think I had it set to 0 first ran like **** but then move it to 4 ran alil better so I'll try 8 and 10...doesnt it go like this,i might be wrong..this my first time doin anything todo wit timing usly just sent off to a shop but cost me 900 the last time.the guy ripped me off big time so I gotta learn all this now..thanks for ur help
10° 8° 6° 4° 0° 2°
Old Mar 10, 2011 | 10:57 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
There's a single tan wire connector you must disconnect before you set the timing. Its located by or near the blower motor on the passenger side of the engine. Since you don't live in California you could set at 8*. Cali cars are at 6*.
Old Mar 11, 2011 | 12:17 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
6 degrees with est unplugged
Old Mar 11, 2011 | 09:14 AM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Old Mar 11, 2011 | 03:20 PM
I have it at 6 deg it runs alot better but after givin alil gas it seems to shake alil or knock what ever you call it....should bump it up to 8 deg to loose the knock in the engine or is this another prob I have now
Old Mar 11, 2011 | 05:42 PM
I tried 6 to 8 and over 8 degs....cant make the knockin or shakin go away...its prob alil under 8 deg right now..it seems like it might be good wit power,has it's power and go back like before intake gasket change 2weeks ago now need to find out why the engine skakes or knocks when driving...any thing I should check on it...
Old Mar 11, 2011 | 05:49 PM
VincentZ28's Avatar
Did you unplugged the est wire first before setting the timing?
Old Mar 11, 2011 | 09:36 PM
[QUOTE=VincentZ28;4851659]Did you unplugged the est wire first before setting the timing?[/QUOTE
yes unpluged wit car off then sit timing then turned car off hooked back the est back up and test drived the car
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Linson
Aug 21, 2015 02:12 PM
