Best Performance upgrades 1991 Z28 TPI 305 T5
Old Mar 22, 2011 | 08:19 PM
nhslacrosse2's Avatar
Car: 1991 z28
Axle/Gears: 2.77 posi
I Just bought a 1991 Z28 305 with a t-5 and i was wondering what are some good bolt on products to get some more power. the car has a full exhaust except headers, a MSD coil, new plugs and wires and everything else is stock. where should i go from there? any good bolt ons or more involved suggestions would be appreciated. Thanks
Old Mar 22, 2011 | 09:39 PM
Camaro82Z28's Avatar
Car: '82 Z28
Engine: Dart 406 ci
Re: Best Performance upgrades
How much are you willing to spend? Is the car a daily driver or can you afford to have it out of commision for a week or so? How mechanically inclined are you? Do you just want bolt ons, or do you want to dive into the motor?
I would most definitely start with headers as the stock manifolds are the biggest bottleneck on your car.
Old Mar 22, 2011 | 10:25 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
You're going to get more answers, faster, if I move this to the TPI board (which I'm doing now). Also, do a search, the mods are pretty common.
Best wishes to you.
Old Mar 22, 2011 | 11:37 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: Best Performance upgrades 1991 Z28 TPI 305 T5
i Agree with 82Z28
I would start off with some headers
Theres very few upgrades you can do to a 305. The cam in it is really small. YOu could get an Lt1 cam but its essentially the same size. Get an open element breather if possible. i have a throttle body so im not sure of what you can and cant do to a tune port
Old Mar 22, 2011 | 11:47 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
with tpi as far as intakes you can go k and n drop in or cold air induction for some extra hp
Old Mar 22, 2011 | 11:48 PM
high flow runners are prolly like $700 and not gonna give you much of an increase
Old Mar 23, 2011 | 08:05 AM
Car: 1991 z28
it is a daily driver but i could afford for it to be out of commission for a while if need be. im pretty mechanicly inclined and i am very willing to dive into the motor. i was looking at roller rocker arms, any suggestions? but i would also like some more basic bolt ons.
Old Mar 23, 2011 | 09:16 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I'll concur that a nice set of headers would be a great improvement!
Old Mar 23, 2011 | 10:32 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
The 1.6 rocker arms work very good on my 1991 305 TPI, they are easy to instal. I also recommend headers.
Old Mar 23, 2011 | 05:14 PM
Car: 1991 z28
what brand rockers would you reccomend and will i have to change anything else to make them work?
Old Mar 26, 2011 | 08:54 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
It all depends how much you want to pay, or what quality you want.
Comp cams 1418-16 Steel roller tip are around $170-$190.
Comp cams 1618-16 Chromemoly steel ful roller are around $325-$335.
Comp cams 1016-16 Aluminium full roller are around $350.
You do not have to change anything else.
I would stay away from cheap ebay aluminium rocker arms.
Old Mar 26, 2011 | 10:40 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Originally Posted by dylanjessy
i Agree with 82Z28
You are incorrect. He has a 5-speed car and it all ready has the bigger LT1 size cam. It is the 305 TPI automatic cars that have the peanut cam.
Personally, I recommend 3.73 gears, cut out the airboxs, descreen the maf, airfoil, grind out the bumps in the plenum, and install some headers, also on a 5-speed car a set of underdrive pulleys will probably work nicely.
Old Mar 26, 2011 | 11:15 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I disagree with descreening the MAF as that has will cause problems with the MAF reading air coming into the engine.. It has been covered before.
I think you should start with regular maintenance items like:
-Full Synthetic oil (Mobil 1, Valvoline, Amsoil, Royal Purple, etc.) and good filter (k&n)
-K&N air filters in the airbox
-Spark plugs and wires and cap&rotor (accel or msd or any other good brand)
-New fuel filter
-Replace Oxygen Sensor (3 wire sensor if you are getting headers so that it gets warm enough to function properly, otherwise a 1 wire sensor will do just fine..)
Then a few other misc. things to do:
-Throttle body coolant bypass (keeps air that enters the engine cooler)
-Cut the airboxes (the stock airbox is good enough for TPI engines, no need for a "cold air intake" ex: those cone filter type intakes.. useless.)
-Throttle body airfoil
-Install a cooler thermostat so your engine runs cooler
A little more advanced things to do:
-Port the plenum & intake manifold (you could also get a used set of bigger runners like AS&M, that's what I did and it still does the job right)
-Rebuild heads (1.6 Roller Rockers, port and polish, etc.)
-Bigger cam
-Headers
-Install posi-traction carrier in rear (if you don't have it already) and put 3.73's (biggest performance improvement for acceleration that you will feel!) This will require new speedometer gears in the tranny, which cost potentially up to 70$ depending on what you currently have in there..
-Once all these mods are done, you will want to give your car a better tune to make the most of all these mods (off the shelf chips do NOT even come close to the performance of a custom tuned chip made by yourself if you know what you are doing..)
Other things you can but shouldn't do for emissions reasons, and will need you to re-tune your computer:
-Remove AIR (Smog pump) and gut the catalytic convertor
-Remove EGR valve and block off
-If you have 9th injector, remove & unplug, and block off
Other suggestion is weight reduction! Less weight will let your car accelerate, handle and brake faster.. Examples of things to reduce weight with: remove ac (personally this is not needed in Canada except for maybe a few hot days in summer but to each his own, plus I have t-tops), hitachi mini starter, aluminum water pump, aluminum intake manifold, headers, remove smog&air&9th injector (very small but everything helps), etc..
That's all I could think of for now!
Old Mar 26, 2011 | 03:16 PM
Car: 1991 z28
the can has new plugs and wires, im doing full synthetic oil and other basic tune up parts and i was planning on trying to make my own kind of ram air set up by doing this https://www.thirdgen.org/ramair has anyone every done anything like this and is it worth it? thanks
Old Mar 26, 2011 | 10:20 PM
burnout88's Avatar
Car: 88 IROC
I have had mine descreened for 15 years now and it causes no issues only improved airflow. I can data log my car all day and confirm for you it causes no issues. When these cars first came out it was one first mods to do along with gutting the air boxes. I always laugh when I hear people making these ridiculous arguments about how it's going to hurt your car and the MAF readings. More airflow always helps performance.
Old Mar 26, 2011 | 10:29 PM
Car: 1991 z28
when you say to gut the air box what exactly do you mean?
Old Mar 26, 2011 | 10:40 PM
burnout88's Avatar
Car: 88 IROC
It refers to the lower airbox. The area where the air filters sit. There is a bunch of plastic in their that can be cut out to open up the airflow. Here is a pic of mine cut out. Now go take a look at yours and you will see what I mean.
Attached Thumbnails Best Performance upgrades 1991 Z28 TPI 305 T5-img_2554.jpg   Best Performance upgrades 1991 Z28 TPI 305 T5-img_2553.jpg
Old Mar 27, 2011 | 02:06 PM
As I said, I disagree with doing this "mod" for various reasons. It's very likely that in the last 15 years your car has not been damaged from it, but I doubt you gained anything from cutting out screens since the MAF is not even the restrictive part of the system, unless ofcourse the rest of your system flows more than 517CFM.. -->
Stock TPI Bosch MAF sensor w/ screens -- 517.8 cfm
Stock TPI Bosch MAF sensor w/o screens -- 658.4 cfm ..
Now, CFM flow aside, there are very good reasons why it is probably better to just leave it alone (even if you know what you are doing on how to cut them out, along with the fins, properly) as there is evidence that suggests and maybe even proves that it does mess with the MAF readings. -->
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
This site explains why the whole hype about this "free mod" was just hype, unless you have a massively modified TPI engine/intake.
While I do agree with you that, in theory, more airflow generally improves performance, but I do not think that most TPI engines (especially stock ones) will net any HP gain from more airflow in this particular part of the system as it is not the bottleneck of the system.
Old Mar 27, 2011 | 07:48 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
I don't think you are going to gain much from a rocker arm swap. Maybe a few hp. I would go and find a set of headers and matching ypipe. Also, the ram air idea should work good too. You could always look on ebay and buy a cold air induction kit too. A good chip can help. I heard Ed Wright from Fastchips makes good chips. I would get it set to use a 160 degree thermostat and to turn fans on much earlier too. Tuning makes a big difference on these cars.
Old Mar 27, 2011 | 07:51 PM
ninetyone's Avatar
Axle/Gears: 3:42
If you insist on rockers though. I have heard that Comp magnum roller tip rockers will clear the centerbolt valve covers. Some rocker arm brands out there will not clear your stock valve covers though.
Old Mar 27, 2011 | 08:27 PM
Car: 1991 z28
what does tuning exactly intail?
Old Mar 27, 2011 | 10:28 PM
ninetyone's Avatar
Axle/Gears: 3:42
data logging and or custom chip burning.
Old Mar 27, 2011 | 10:32 PM
ninetyone's Avatar
Axle/Gears: 3:42
That is why i suggested you order a pre-tuned mail order chip from Fastchips or Pcmforless. They are supposed to be a little better than say Hypertech or Jet chips.
Old Mar 28, 2011 | 08:32 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
umm 91 is MAP car....has no MAF to descreen
Old Mar 28, 2011 | 10:05 AM
Yes 91-92 used SD (speed density) TPI systems. I just wanted to clarify that descreening the MAF isn't worth it, for anyone reading this thread.
Old Mar 28, 2011 | 04:48 PM
camaroman9191's Avatar
I will be rebuilding my 305 in a few months.. It is the same as your car.. 1991 305 TPI with the T5.. I will be doing a new comp cams computer controlled compatible .510 lift cam, Keith Black 10:1 compression pistons, headers and a Y pipe from flowtech and new 24 Lb/ Hr injectors. However the car is getting dyno tuned after this. I also will be adding new roller rockers from Procomp Electronics. I dont know if anyone has heard of them but my father and I have been using them for years now and have never had a problem with their products. Thats just what I'm doing. Hopefully it will be around 300 HP. I do know for a fact the 90-92 TPI cars with the MAP sensor setup( also called Speed Density) is VERY tempermental when it comes to cams and such. I would suggest having your car properly tuned if doing a cam or anything. True dyno tuning is much better than just ordering a chip from a website. Anyways.. All the best with your project! hopefully I gave you a few Ideas
Old Mar 28, 2011 | 09:38 PM
burnout88's Avatar
Car: 88 IROC
Yep, 91 is SD so I guess he has no MAF to descreen. But I disagree and it is worth doing. That is just our "opinion" based on nothing of value. Not a fact.
Old Mar 28, 2011 | 10:26 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Guys...please agree to disagree about the screens. That particular topic has been one of much contention for years.
nhslacrosse2...I would buy some used SLP or Accel runners, port the plenum, and get some headers (1 5/8 primaries will be easy to install), but I understand Dyno Don's are the best (they are 1 3/4 primaries).
Old Mar 28, 2011 | 10:46 PM
No worries I was merely passing on info from what i've read on the net from various sources, which in fact may or may not be right for all I know. Although I would recommend anyone interested in doing it to do their own research and come to their own conclusion, rather than doing something based off of someone's opinion, such as mine or burnout88's... I apologize if I've come off harsh, wasn't the intent
Old Mar 30, 2011 | 04:06 PM
1badnova's Avatar
Car: 71 Nova / 91 1le z28
Engine: 406 sbc / 305 lb9
Transmission: 700r4 / t5
Axle/Gears: 4.11s 8.2 / 3.42s
Can someone elaborate on how much those roller rocker arms helped? Is there even a appreciable difference?
Old Mar 30, 2011 | 04:21 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
"Theory says if you replace a stock 1.5:1 rocker arm with a 1.6:1 rocker, valve lift will increase throughout the lift curve. Let's take a small-block cam with a max valve lift of 0.450 inch with a 1.5:1 rocker arm. Install a 1.6:1 rocker and the max valve lift jumps to 0.480 inch. That's a healthy 0.030-inch increase in valve lift."
http://www.chevyhiperformance.com/te...ers/index.html
Old Mar 30, 2011 | 04:51 PM
1badnova's Avatar
I have a 91 1le w/ a 305 lb9, she's already got shorty headers, underdrive pulleys, jacobs elec ignition and it runs pretty good but looking for a little more w/o going into the motor or boost. 3/8 stud on these motors correct? Do they need self aligning ones or no?
Old Mar 30, 2011 | 05:06 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
3/8'' stud, self aligning.
Old Mar 31, 2011 | 07:26 AM
In theory, they're said to give a 15-20 HP gain if you get just the roller tip rockers. If you go to the full blown full roller rocker there's probably even more HP unleashed there. I belive they just work on the principle that they cut down on drag, friction, and a parasitic load put on the engine by moving 2 surfaces past each other that dont have a bearing. Also they wear less. I have a comp cams 1.6:1 set on on my 91 305 TPI and I can say that I felt a difference, no doubt about that but its not like all of sudden you're driving a rocket ship. I've also heard that they can actually screw up your cam geometry potentially causing problems which is why im getting rid of my 1.6:1 set and replacing with a full roller 1.5:1 set when I do my cam swap.
Old Mar 31, 2011 | 08:15 PM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
I have an 89 Camaro, That had a 305 tbi, I dropped in a tbi 305 off of a 93 caprice. rebuilt the heads, and changed out the gaskets, sensors(temp,intake,oil.) As they tend to do it overheats. I want to put a 3 core radiator, new fan switch, new thermostat, and chip. What should i do? What can i do to restore this project to its old self. Dont really care for horsepower, just want to restore it, maybe add a few new parts. Its my daily driver. My goal is to repaint it and have it look and run as stock as possible. Chevy ****ed up on designing the heads. Two exhaust ports side by side. Would headers relieve some of the stress?
Old Mar 31, 2011 | 08:16 PM
correction (overheated)
Old Jun 29, 2017 | 11:53 AM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Does anyone know of a thread that will help a 92 z28 350 do 5 seconds 0 to 60..lol
jklein337
Sep 19, 2018 06:23 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
