TPI Shudder/Shake while accellerating
Old Jun 20, 2011 | 11:00 AM
  #51
hairysox33's Avatar
Re: TPI Shudder/Shake while accellerating
Old Jun 20, 2011 | 02:03 PM
  #52
Ronny's Avatar
I suspect: TPS is bad/needs adjustment. I just don't understand how you set the TPS...
It may not be able to be adjusted. Non adjustable. Connect a "jumper" with volt meter to it and verify with engine off key on the 0% TPS at about .50 volts. Then slowly advance the throttle and see a "smoooth " progression to 4.5V. If it jumps around it needs replacement. CE should have come on with code if bad TPS. I would check it anyway to rule it out.
Old Jun 20, 2011 | 02:51 PM
  #53
hairysox33's Avatar
Thanks, but post #13
"TPS Voltage was solid at .55 Volts resting, and about 4.2X Volts at WOT."
Tunerpro5 says its .54 volts resting with the key on.
Old Jun 20, 2011 | 03:22 PM
  #54
Ronny's Avatar
Is the transition smooth? May be jumpy?
Old Jun 20, 2011 | 03:56 PM
  #55
hairysox33's Avatar
Yes, smooth, and consistent with pedal position.
If you'll look at the screenshot that Torn posted on the last page, you'll see the issue described. Pretty sure its not TPS related.
arem04667
Dec 17, 2012 10:35 PM
FFCam1991
May 9, 2010 04:04 PM
joey 350 LT4
Aug 11, 2009 10:53 PM
gurkgurkgurk
Mar 6, 2009 10:32 PM
martyr
Feb 16, 2004 03:07 PM
