Cleaning out my TPI
Old May 24, 2011 | 03:45 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Cleaning out my TPI
What is the proper way to clean out the insides of a tpi system? It seems silly to just spray loads of harsh throttle body cleaner, there has to be a better way. Can I soak it in something like a dirty dish and wire brush it out? A spray bottle of seafoam?
Old May 25, 2011 | 09:22 PM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Re: Cleaning out my TPI
I took it all apart and soaked everything in carb cleaner, worked awesome. All that carbon just got blasted away. I used a stiff bristle brush to get the more stubborn areas, and probably went through 2 or 3 cans of cleaner.
Old May 26, 2011 | 09:09 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
It's safe to soak aluminum in it? I didn't want to have to use so much of the stuff cuz I don't want to have to worry about disposing of it. Does simple green have any effect? Good or bad? At least that stuff's biodegradable.
Old May 27, 2011 | 11:46 AM
tommygun's Avatar
Engine: 5.7 TPI
Well, for the disposal, I can't really help you there. Not the most environmentally friendly operation- I just soaked and sprayed it on some wood boards on my gravel driveway- it evaporates, although the carbon hangs around until it rains enough. As for being safe to use on aluminum, I can't see where there would be a problem. (BTW, aren't most carburetors made of aluminum?) Didn't mess with mine at all. Simple Green won't really work- that carbon is really ON there. I guess another option would be to take it to a shop and have the components ultrasonically cleaned.
Old May 27, 2011 | 04:04 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Yeah I went ahead and used two cans of intake cleaner. I hope mother earth forgives me. The engine seems to appreciate it though. Some timing and tuning and she should run like new.
Next time though, any idea how much a shop charges to clean parts like the intake?
Old May 27, 2011 | 05:46 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
LOL hope mother earth forgives you? You drive a V8 car built in the 80's. I'm not saying intentionally destroy the earth, but go drive a friggin' econo box if you are that hung up on that.
Anywho. Seafoam if the intake is still on the car will do the best cleaning job.
Intake off the car, wire brush and purple power (or your favorite degreaser) that is how I cleaned mine up.
As for a shop doing it Sonic cleaning is affordable, prolly like 40-60 bucks for the upper, lower and runners would be my guess, I could be wrong. I think I paid 20 bucks to have a pair of heads put through a head washer.
Old May 27, 2011 | 08:16 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
I was hoping you'd appreciate the irony. Thanks for the tips, I actually just seafoamed the ol girl as well and found a fantastic exhaust leak (investigating this in another thread).
Old May 28, 2011 | 02:38 PM
LOL okay, I work with some tree huggers that give me **** about my "horrible gas guzzling sports cars" That are "destroying the environment" I tell them if they are so high and mighty they should walk to work.
Old May 28, 2011 | 06:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
how can there be tree huggers in the valley? lol should the official name be cactus hugger? i NEVER walked anywhere when i was in AZ lol id fire up the gas guzzler and go where i needed to lol even the mail box...but i was in QC so it was about a half mile away lol
As far as the cleaning goes i opened the throttle plates and just sprayed seafoam in, when i did a set off the car i just threw it in a bucket of degreaser overnight
Old Jun 4, 2011 | 10:44 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I wouldn't use simple green on aluminum, it seems to leave a wierd "finish" on it. I used some dollar store crap called "Awesome" It was cheap and worked very well. I soaked everything down, off the car then blasted it with my pressure washer and it blasts all the crap off. Wait till those treehuggers have to dispose of thier dead batteries, then ask them again how good that is for the enviroment. If they were seriuos about that crap they would live like the Amish. It's never been about the enviroment anyways, Its about controlling peoples lives. Thats all they really care about. F' em.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
