best tpi mods
Old May 31, 2011 | 09:57 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
best tpi mods
This is just for fun but what is the best tpi mod you have done? Could be engine mod, suspension, drivetrain...
Old May 31, 2011 | 10:22 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: best tpi mods
just for fun huh... i have quite a few mods... take a look.. i think its my hobby...
ENGINE MODS......
fresh 355 bored .30 over 4 Bolt Main Vortec Block
10243880 Gm cast Block
Blueprinted Performance build ( bored with thrust plates)
9.7 to 1 Compression
Milodon Main Cap Bolts
Eagle 5140 Forged Steel "SIR" Lightweight Connecting Rods
ARP Rod Bolts
Eagle 4340 Forged steel crank
Upgraded Clevite 77 H Bearings
Kieth Black Hypereutectic -12cc dished pistons
dura-bond hi performance coated cam bearings
Pioneer heavy duty brass freeze plugs
Internally Balanced Eagle rotating assembly (rated at 650 horsepower)
LS7 Lifters
Heavy duty flywheel
New harmonic balancer
LT1 mini Starter
Highflow radiator
High flow water Pump
ARP headbolts
Rebuilt L98 heads with manely springs, retainers, screw in studs
SA performance double timing chain
GM LT4 HOT Cam
218/228 .492"/.492" 112 LSA
Comp Cams 1.5 roller tip rockers
INDUCTION/FUEL DELIVERY MODS.....
FIRST Injection TPI unit (300cfm stock)
73mm mono-blade throttle body
Aeromotive Adjustable fuel Pressure regulator
Custom Fuel Lines
SLP's CAI with K&N air filter and SLP's special modded intake hoses
IAT relocated to SLP CAI box
180 thermostat
Hypertech 4028 200/185 degree fan switch
SVO 24lb Injectors
Heated O2 sensor
OIL SYSTEM MODS.....
Melling 10553 Oil pump
hardned pick up
L98 Oil Pan
Gauges
stock gauges with white face gauges
blue led gauge lights
Autometer trasnsmission temp gauge
SUSPENSION/CHASSIS MODS......
WS6+ suspension
aggressive street alignment (vetrucks specs)
Kuhmo Ecsta Ast 245/50/16 tires 30psi
Spohn Front end rebuild kit with poly tie rods
UMI Adjustable Strut mounts
KYB GR-2 Front struts
KYB Gas-a-just rear shocks
Eibach Pro-kit lowering springs
Heater hose spring mod
36mm front sway bar with poly bushings
24mm rear sway bar with poly bushings
Stock painted A arms poly bushings and poly ball joints
new poly front and rear sway bar endlinks
Front K-member Braces
UMI Steering Brace
BMR Strut Tower brace
BMR weld in outer subframe connectors
Alstons weld in Inner subframe connectors
BMR non adjust Torque arm with poly bushing
Edelbrock On car Adjustable panhard bar poly bushings
J & M Street non adjust Lower Control Arms
Founder Performance lower Control arm relocation Brackets
Transmission Mods........
Pro-Built 700R4 (rated at 600 hp)
corvette stall
Pan drilled for autometer temp gauge
B&M Shift Kit
Corvette Servo
tranny poly mount
Tranny cooler
Rear End mods.........
9 Bolt Borq warner 3.27 Gears
aluminum driveshaft
Neapco brute force u-Joints
EXHUAST MODS......
Hedman longtube Street headers
Custom 3" y-pipe
Catco highflow Gutted converter
Flowmasters 80’s series 3.5 inch catback
IGNITION MODS......
New distributor
MSD 8.5 super conductor wires
accel Super coil
EXTERIOR MODS.....
83 trans am Powerbulge cowl hood with carbon fiber locking pins
aftermarket hood insulator
20 percent window tint all around
Factory aluminum louvers
black Gta emblem swap
blacked out tailights all around
INTERIOR MODS......
New Headliner
New carpet
redone GTA bucket seats with trans am stitched in headrest
redone rear seats
usa speed Beechwood floor mats with gold bird and trans am stitched in
redone sunvisors and side speaker covers
power to manual door conversion
Grant black 773 steering wheel with ponitac horn button
Dash pad cover with gold bird emblem stitched in
olive ash Dash kit with painted black dash and console
white face gauges with blue led lightning
blue led floor lights
Magellan GPS mounted on dash
ipod holder mounted on dash to connect to HD radio
white face HVAC with red led lighthing
ashtray delete coin holder conversion
red shift indicator led conversion
camaro Z28 auto leather shift ****
new black leather shift boot
SOUND SYSTEM MODS:
Kenwood MP242 HD radio with dash kit
new factory replacement speakers
custom sub box with 12" infinity subwoofer
800 watt amp with blue lightning
MISC MODS.......
150lb weight reduction
tuned by PCMforless
rev limiter set at 5500rpms
New belt Tenisoner and pulley
AC delete pulley
New delco Alternator
Throttlebody Bypass delete
Oil Cooler delete
diverter valve delete
cruise control Delete
Washer fluid Delete
Cold Start Delete
Cat Delete
AC delete
EGR delete
Heater valve delete
Air delete
smog delete
Vats
Old May 31, 2011 | 11:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: best tpi mods
ENGINE MODS......
ARP Rod Bolts
LS7 Lifters
Heavy duty flywheel
LT1 mini Starter
Highflow radiator
ARP headbolts
GM LT4 HOT Cam
Custom Fuel Lines
180 thermostat
SVO 24lb Injectors
Heated O2 sensor
hardned pick up
L98 Oil Pan
Gauges
WS6+ suspension
UMI Steering Brace
corvette stall
B&M Shift Kit
Corvette Servo
tranny poly mount
Tranny cooler
aluminum driveshaft
EXHUAST MODS......
Custom 3" y-pipe
IGNITION MODS......
New distributor
accel Super coil
EXTERIOR MODS.....
INTERIOR MODS......
New Headliner
New carpet
redone rear seats
SOUND SYSTEM MODS:
MISC MODS.......
tuned by PCMforless
AC delete pulley
Oil Cooler delete
Washer fluid Delete
Cold Start Delete
Cat Delete
AC delete
EGR delete
Heater valve delete
Air delete
smog delete
Vats
Wow lots of mods i bet thats a really fun street car
Old Jun 1, 2011 | 01:02 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: best tpi mods
of those which one was the best for you?
Old Jun 1, 2011 | 06:54 AM
88fastgta's Avatar
Re: best tpi mods
thanks this started out as just only flowmasters to make it sound better but then it slowly snowbaledl into basically a street/strip car.... i say the best things were the suspension mods.... with more power its hard to keep it all to the ground and it just feels like poo without some sort of frame connectors and poly bushings.. the tubular pieces and bushing really made the car feel way different... my car feels like a go cart because its so stiff... my suspension is done... i just want to get a set of afr heads and a vigilante 2800 and my hotrod days for this car is about done... only thing left would be paint/body work for shows....
Old Jun 2, 2011 | 11:45 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: best tpi mods
Oh ok so suspensions youd say about first before anything else. Also not to get off topic but i bet your car is really quick from 0-60.
Old Jun 2, 2011 | 09:29 PM
88fastgta's Avatar
Re: best tpi mods
yea if i had to do it all over again i would start with suspension mods first.. that way you have a good chassis and foundation to build upon..... but yeah it was quick from 0 to 60 about 4.5 seconds when i stalled the converter which at the time i had a 10inch 3000 stall converter.... should be quicker when i install my FIRST injection tpi system...
Old Jun 3, 2011 | 11:10 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: best tpi mods
Wow pretty quick then im also building up a 350 for my z28 but im gonna keep stock tpi unless i find some as&m runners at a good deal
Old Aug 30, 2011 | 08:32 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
Re: best tpi mods
what is the HEATER HOSE SPRING MOD?
Old Aug 30, 2011 | 08:49 PM
88fastgta's Avatar
Re: best tpi mods
its when you take the rear hard rubber isolators that the springs are on top of.... take a piece of heater hose and cut it and slip it through one coil on each spring then install spring... it lowers the car about a half an inch... the isolators are there so the springs wont have metal to metal contact with the body but they are big and make the car sit taller... alot of people do it when lowering their car..
Old Aug 31, 2011 | 08:44 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: best tpi mods
Suspension mods first is right, after exhaust....you will love the go kart feeling you get when you tighten up everything on these cars....
Old Sep 27, 2011 | 03:46 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: best tpi mods
I agree suspension is a must! I changed out my stock sagging springs for some moog springs that I cut to get the ride height I wanted and its like abother car. Can't wait to get some subframe connectors and all new bushings under it this winter.
Old Sep 27, 2011 | 05:13 PM
Car: 90 Iroc
Re: best tpi mods
can you do something like that to the front? beside cutting the spring..lol
Old Sep 28, 2011 | 06:21 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: best tpi mods
you will love your connectors...I swear my car freaks me out when I drive it...It is such a joy...I don't have any hi dollars pieces in it, but it was all thought out pretty well...The only thing I do not have is a shock tower brace, and I am waiting till after the new motor goes in to put one in the car...
Old Sep 28, 2011 | 09:28 PM
Screamin86's Avatar
Re: best tpi mods
Hat sfcs are you running? I've seen some people run two diff sets also. Mines going down to replace the caved in oil pan put some headers on it custom fabed y pipe and maybe a cam that I can pick up from a friend but sfcs are a must along with a wonderbar and maybe a strut bar.
Old Sep 29, 2011 | 01:29 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: best tpi mods
Hothkis..(will never buy again) I had to custom fit my y pipe also...Had to have a welding shop fab it up, as it was 4 inches, or more too long towards the passenger side of the car....Wonder bar is nice...Cant believe they all did not come with that...The funnest thing I ever added to my 89 was the stall...Like a different car, and I love the sound of riding the stall..I know it heats the tranny up, but thats why ive got a tranny cooler the size of Texas..lol....
Old Sep 29, 2011 | 04:41 PM
Screamin86's Avatar
Re: best tpi mods
Yes a stall is a lot of fun! I went from a stock stall to a 9.5in 3500 in my 82 trans am and it felt like I gained 100hp lol
Old Sep 29, 2011 | 04:52 PM
thegooseman's Avatar
Car: 1992 RS
Re: best tpi mods
Seeing a thread similar to this on tech, one member said and I am sure I will feel the same way when I get one. It went something like this.
A stall. Because it made all my other mods that much better.
Old Sep 29, 2011 | 04:59 PM
Screamin86's Avatar
Re: best tpi mods
After I'm thinkg some more seems like mod list shoud go suspension/chassis full exhaust gears/stall (if auto).
Old Sep 30, 2011 | 09:31 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Re: best tpi mods
ENGINE MODS......
ARP Rod Bolts
LS7 Lifters
Heavy duty flywheel
LT1 mini Starter
Highflow radiator
ARP headbolts
GM LT4 HOT Cam
Custom Fuel Lines
180 thermostat
SVO 24lb Injectors
Heated O2 sensor
hardned pick up
L98 Oil Pan
Gauges
WS6+ suspension
UMI Steering Brace
corvette stall
B&M Shift Kit
Corvette Servo
tranny poly mount
Tranny cooler
aluminum driveshaft
EXHUAST MODS......
Custom 3" y-pipe
IGNITION MODS......
New distributor
accel Super coil
EXTERIOR MODS.....
INTERIOR MODS......
New Headliner
New carpet
redone rear seats
SOUND SYSTEM MODS:
MISC MODS.......
tuned by PCMforless
AC delete pulley
Oil Cooler delete
Washer fluid Delete
Cold Start Delete
Cat Delete
AC delete
EGR delete
Heater valve delete
Air delete
smog delete
Vats
That is a disgustingly awesome list of mods. I probably want to carry about 90% of those in to my GTA someday. Lol
Old Oct 11, 2011 | 08:12 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: best tpi mods
How hard is that mod? Was your ride any less bumpy after?
Old Oct 11, 2011 | 09:04 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: best tpi mods
Car will not ride less bumpy after. Everything is the same, but the spacer is removed from the top of the spring so the body will sit a little lower to the ground.
It's very easy to do. Jack the car up, unbolt the lower shock mounts, and the springs and upper spacers will fall out. Put rubber heater hose on the top 3/4 turn of the coil to isolate the spring from the body.
Old Oct 11, 2011 | 09:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: best tpi mods
what size heater hose do you use? and how much lower does the car get? about an inch ?
Old Oct 11, 2011 | 09:18 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: best tpi mods
I forget, it might be 1/2", but just to be safe, 5/8" will be o.k. Use cable ties to hold it on the spring.
Won't lower the rear an inch, but most likely a 1/2". Not bad for almost free.
Old Oct 11, 2011 | 09:24 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: best tpi mods
CAM, HSR, HEADS a must from day one
Old Oct 12, 2011 | 01:29 AM
Z28Smitty's Avatar
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Re: best tpi mods
My best mod was subframe connectors. Really made a big difference in how the car handled. After doing suspension mods to improve the ride, brakes are next on the list followed by performance mods. Pumping up the horsepower without improving the **** poor 3rdGen brakes is a recipe for desaster.
Old Oct 14, 2011 | 01:34 PM
88gta3508's Avatar
Engine: 231 / 383
Re: best tpi mods
You 3rd gen owners can't be serious!!! Suspension first??? Do you like getting spanked by almost every car like. grand AM's and such... I had every suspension mod inclueding wonder bar, sub frame connectors.. great mod... But engine MODS.. are # 1 priorty...
Old Oct 14, 2011 | 03:28 PM
Screamin86's Avatar
Re: best tpi mods
Most stock cars nowadays are faster than most stock 3rd gens and I'm ok with that. Don't get me wrong I love a fast thirdgen but I want it to be fun to drive in and out of traffic and have fun on backroads. If you start to make more power and the car was setup for a 200hp motor your gona spin spin spin lol. My cam stalled 305 in my 82 will kill the tires from a 30 roll and all the suspension and chassis was bone stock.
Old Dec 24, 2012 | 10:58 AM
jjbced's Avatar
Re: best tpi mods
ENGINE MODS......
ARP Rod Bolts
LS7 Lifters
Heavy duty flywheel
LT1 mini Starter
Highflow radiator
ARP headbolts
GM LT4 HOT Cam
Custom Fuel Lines
180 thermostat
SVO 24lb Injectors
Heated O2 sensor
hardned pick up
L98 Oil Pan
Gauges
WS6+ suspension
UMI Steering Brace
corvette stall
B&M Shift Kit
Corvette Servo
tranny poly mount
Tranny cooler
aluminum driveshaft
EXHUAST MODS......
Custom 3" y-pipe
IGNITION MODS......
New distributor
accel Super coil
EXTERIOR MODS.....
INTERIOR MODS......
New Headliner
New carpet
redone rear seats
SOUND SYSTEM MODS:
MISC MODS.......
tuned by PCMforless
AC delete pulley
Oil Cooler delete
Washer fluid Delete
Cold Start Delete
Cat Delete
AC delete
EGR delete
Heater valve delete
Air delete
smog delete
Vats
That is a massive list!!! I have a 91 z28 TPI 350, the previous owner bored out .30 over, flow master and put 42lb injectors in it but its still not enough power for me. I'm thinking about pulling the motor and rebuilding it with some performance enhacements, my only concern is I live in california and we have smog ****'s here. Do you have any suggestion on what would give me a good kick but still keep me smog legal? A lot of people say cam but they dont have any advice on what one.
Old Dec 24, 2012 | 11:17 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: best tpi mods
First thing you need to do is take out those 42lbs injectors and put the stock 22lb back in. That will increase your performance. You dont need them and the chip is not burned for them.
Get a set of Dyno Dons dual cat headers. Thats all you need for now. Later on down the road save up your money to buy heads, cam, and all the intake parts that you will need.
Old Dec 24, 2012 | 04:40 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: best tpi mods
Yeah start with the headers they wake it up a lot and 42 Ib injectors, The guy before you had it supercharged or something cause those are huge! If you wanna sell them tell me how much I maybe interested in them!!!
Old Dec 24, 2012 | 04:43 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: best tpi mods
42Ib injectors on a na engine can supply over 500 hp! if you arent using it, your losing it
Old Dec 24, 2012 | 09:27 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: best tpi mods
Start with a full exhaust. I ran a 14.8@93 stock. Then I ran a 14.04@98 with hooker 2055 headers, 3" y pipe. 3" cat back and a afpr. Still had the 2.77's in the car. I was so close to 13's with a 2.77 rear and bolt ons. I only got 3 runs in. Then I started the h/c/I swap.
Old Dec 24, 2012 | 09:54 PM
VincentZ28's Avatar
Re: best tpi mods
I ran 13.6 @ 103 with SLP 1 3/4 dual cats and 3in cat back Maxiflow Hooker exhaust and no other bolt on with 3.23 gears.
Wade787b
Sep 29, 2015 01:15 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
fbirdroller
Sep 2, 2015 10:27 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
