Emissions failed - HC at Idle
Old Jun 5, 2011 | 10:23 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I failed by about 2x and they give you a list of things it could be such as cat., rich fuel, EGR, oxygen sensor, etc.
Would a brand new cat. cause it too? It was put on the same day but I did not have insurance to 'break' it in over days so only drove it for 1/2hr to get up to temperature. That day the exhaust was stinky (paints burning smell) but now it is normal.
No dummy lights were on so I doubt any sensors were bad.
Old Jun 7, 2011 | 02:40 PM
camaropower88's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: L98 350 TPI
Axle/Gears: 2.77 posi
Re: Emissions failed - HC at Idle
sadly, HC doesnt tell much of the story. HC is RAW fuel, meaning it did not burn at all or begin to burn. Thats what CO is. CO is the byproduct of INCOMPLETE combustion. You can have excessive HC from either a rich or lean condition. You need the CO and O2 readings to actually tell lean or rich. O2 higher than the CO is lean, and CO higher than O2 is rich. Now on the emissions test sheet you get back it does not have an O2 reading. If you only failed for HC you most likely have a lean condition, sometimes depending on how severely lean you are you can also fail for Nox, and BARELY fail for CO as well, such as I did. Check for vaccuum leaks and check your fuel pressure, make sure your fuel system is good and you are getting enough fuel. Failing emissions is just an imbalance of the air/fuel ratio. Like i said you need O2 readings and CO to determine which way the air/fuel ratio is being altered so you have a starting point, whether that is diagnosing a lean or rich condition. Hope this helps at all.
Old Jun 9, 2011 | 05:51 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
we'll need the rest of the test results to have a better picture of your car. like NOx, CO, CO2. all that jazz
Old Jun 9, 2011 | 06:04 PM
Engine: L98 350 TPI
Old Jun 25, 2011 | 10:24 PM
Dennis-Z28's Avatar
went again today after a couple hundred kms to break in the cat. FAIL (just barely)
Driving test:
HC = 35 (86 allow) PASS
CO = 0.10 (0.57 allow) PASS
NOx = 779 (852 allow) close PASS
Idle test:
HC = 84 (82 allow) FAIL
CO = 0.36 (0.50 allow) PASS
My last test before that my NOx was way down at 149 in the driving test but my HC in the idle was up at 101. No check engine codes so not sure where to start looking. Maybe the repair shop
Old Apr 15, 2013 | 11:09 PM
Dennis-Z28's Avatar
2 years later and same thing. Pretty much every sensor is newish.
Try replacing the fuel pressure regulator? Suppose I can get the shop to test the pressure, etc. How do you know/test for a faulty injector?
Old Apr 16, 2013 | 03:49 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Have you checked your timing? I've heard that it will not pass if timing is advanced. Should be at 6 degrees BTDC.
Old Apr 16, 2013 | 11:39 PM
Dennis-Z28's Avatar
I have done the timing with the wire disconnected to 6deg BTDC. Seems to be good.
Would a scan tool be very useful so that I can read sensor values? I was thinking the Innova 3120 ($150) or the Actron CP9190 ($270) but both are very expensive and seem more for ODBII anyways. Is there a cheaper option the does scan, and not just code reading (as I can do that with a jumper wire)?
Ohm tested all the injectors at 17.2 Ohms each. Just bought a new fuel reg diagphram. Possibly O2 sensor is fouled by previous valve seal leak despite it only has a 1000 or so miles on it.
Old Apr 17, 2013 | 10:23 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Is the engine stock with all the emissions equipment intact and operational?
What are your current measured/allowed numbers?
How did you get it to pass two years ago?
Old Apr 18, 2013 | 10:42 PM
Dennis-Z28's Avatar
Car is stock except Hooker shorty headers, Flowmaster cat back. Cat is a high flow Magnaflow though which does not help.
Results were a bit worse than 2 years ago. I never passed last time either, I just never drove the car for 2 years. This time:
HC (Driving): Allow=86, Avg=34, mine=49 [PASS, tiny bit high]
CO (Driving): Allow=0.57, Avg=0.08, mine=0.01 [PASS, very good]
NOx (Driving): Allow=852, Avg=125.5, mine=681 [PASS, barely]
HC (Idle): Allow=82, Avg=25, mine=113 [FAIL, miserably]
CO (Idle): Allow=0.50, Avg=0.02, mine=0.66 [FAIL]
Drove my car around that day and got 18mpg avg on a tank (13.3L/100k).
Old Apr 20, 2013 | 01:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
A scan tool might be helpful in reading what the mixture is at idle. Can't really say for certain.
Attached is a pretty good read on combustion and how converters work.
Too bad you don't have the numbers for all 5-gasses at idle and driving (HC, CO, CO2, O2 and NOx)
File Type: pdf
Old Apr 20, 2013 | 02:02 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
ok lets start with the basics here. check all of your ignition components. Plugs, wires, cap & rotor. you should be able to pass with a high flow cat. but you need to get it HOT or it won't work properly
Old Apr 20, 2013 | 02:48 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
gonna be so happy when they finally get rid of stupid aircare
mine failed too and been parked since
https://www.thirdgen.org/forums/tech...reading-s.html
post up this print out may give a better pic of whats going on .....its from their website.
Old Apr 25, 2013 | 12:27 AM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
. I know it won't tell u why its not passing but I'm willing to bet if u bump timing down to either 2* or 0* and rev it to 2500 and hold it there for a FULL 5 minutes right before they pull it in you will more than likely pass. its too close not too. inspector for 3 years . don't worry timing is not an item of inspection. at least not in Texas.
Posted from Thirdgen.org App for Android
Old Apr 25, 2013 | 07:30 AM
Car: 91 Trans Am
Engine: 355 TPI
It's not that it is an item of inspection but it's that it effects the emissions output
Old Apr 25, 2013 | 09:22 AM
well yeah that's my point. pulling timing would help emissions. I meant if it passes after that ,u still won't know what was causing the high amount of hydro carbons. especially if it passed because then you are masking a problem by pulling timing. but IMHO I would rather be searching why its not passing ( in stock form ) with a good sticker on it.
Old May 16, 2013 | 06:22 PM
Dennis-Z28's Avatar
Threw a new O2 sensor on and cross my fingers.
Old May 16, 2013 | 06:25 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Hope you pass. I failed twice and then installed a new oxygen sensor and passed.
Old May 17, 2013 | 04:43 PM
Dennis-Z28's Avatar
Got rained out. I could have done it but I like to make an enjoyable days cruise out of any day I put temp. insurance on.
I did break down and go to a shop though previously and they said O2 sensor was wonky and if that don't work then swap out my high flow cat for a regular one. I also put in a new fuel regulator as it looked leaky but after removing it the diaphragm was okay so doubt that did anything.
Maybe Saturday will shine some convertible rays.
Old May 19, 2013 | 05:52 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Dennis did you make it to the emissions testing? If so did you everything go great?
Old May 24, 2013 | 10:55 PM
Dennis-Z28's Avatar
Woo-hoo! I passed with the new O2 sensor. Everything was well below the limit except NOx on the driving portion which I got 851 out of 852 allowable (whew).
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
