mysterious ticking sound
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
okay guys, ive been experiencing a weird ticking sound from my engine bay. its weird it seems to only come from the driver side of the bay and only does it when im driving i can put the car in park or nuetral and rev it and it wont do it. but when i put it in drive and drive off it starts ticking it follows my rpms and sounds like a card in the spokes of a bicycle its strange the motor is brand new and only has 3k miles on it so id hope it isnt anything in the motor. but you never know i was wondering if anyone could shed light on this. i also tightened my manifold bolts to see if that did it but it didnt help also have had the entire piping up to the manifolds checked for leaks and their wasnt any. hope someone can help
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: mysterious ticking sound
I know you checked, but it still sounds like an exhaust leak. You can find a leak by black stains where it was leaking out, or if you are careful, you can find it with the engine running by very carefully moving your hand around the manifold and pipes until you feel the puffing.
Car: 1986 iroc-z
Engine: 350 tpi.
i will have it checked again, what about the gasket between the manifold and motor. if its burnt out or going bad would it do this?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Car: 1986 iroc-z
Engine: 350 tpi.
ohh didnt know that. well guess i can thow that out of the equation
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
They may have put one there check the collector too.
X2 on exh leak usually only hear under load.
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
With the coolant fan turned off, you should be able to hold a bit of paper towel around the flanges of the manifold.
When the paper towel fluffs you've found your leak.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
if ticking increases in speed as you accelerate ,then it's prob an exhaust leak. More than likely at the manifold or header gasket.
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
I will bring this up only because I've had it happen in the recent past: had the same issue that you're describing, no loss in power, motor only had approx 2500 miles on it and tapping only happened under load. After exhausting every thought I could have, I ended up pulling of the intake and found that a snapped intake pushrod was causing the noise. Hope this isn't your issue and that it's something small and stupid. But figured I'd let you know either way.
Car: 1986 iroc-z
Engine: 350 tpi.
Car: 87 IROC Z-28
Awkwardly enough, it only occasionally did it under reving in park/neutral; typically did it while driving only.
Also another thing that threw me for a bit of a loop, (my noise that I was getting) it didn't do it in rhythm (like you would assume). The tapping kind of varied a bit during driving.
Car: 1986 iroc-z
Engine: 350 tpi.
