'88 TPI Throttle Body - What threads on botom plate?
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
Hey guys,
Anyone here know what threads are used in the bottom plate on the throttle body?
I had an issue when trying to re-do my throttle body on my 5.0 where the torx head screws on the bottom plate were frozen and one head broke off. I got another throttle body for it, cleaned up nicely but when trying to put the bottom plate back on, the threads are a little tight so I want to use a tap to clean them out.
I assume these are metric, but neither my 3 x.6 or 4 x.7 are the right threads.
Did they use something like a 3.5? the 3 is too small and the 4 seems just a bit to large.
Anyone got an idea what they are?
Bruce
Bruce
Engine: 305 TPI LB9
Re: '88 TPI Throttle Body - What threads on botom plate?
Come one, someone out there has to know what threads these are!
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
They are metric threads,I dont't remember what size they were.If I remember I can check thread size at evening after work.
Engine: 305 TPI LB9
Hey Jari,
Thanks!
If you could check the actual size and thread count, that would help me out tremendously!
Bruce
Thanks!
Bruce
Dont know if this would help you or not, but theres an app for the Iphone/Ipod with a thread pitch gauge on it. I use mine all the time. its called Bolt & Nut......
Engine: 305 TPI LB9
I took one of the bolts from the bottom plate over to my local Home Depot and checked the sizing on the thread tool they have there. Would not fit into the 3X.6 but went into the 4x.7, threads seemed right but the bolt wiggled like it was smaller than that size.
This is my concern, if I clean out the throttle body screw holes with the 4x.7, then the bolts will be too small (just slightly) and then will come lose.
Did they make anything like a 3.5X.7 metric?
That's what this seems to be, but I have not seen a tap that size.
Any ideas?
Any ideas?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Any ideas?
Any ideas?
But I would just do it like this:
Turn the TB upside down and spray carb cleaner into the blind holes, and let it sit for a few hours. Then I would clean that stuff out with brake spray and blow the holes dry. Then I would lube up one of the bolts with wd-40 and gently run it into each thread. Clean out the mess with brake spray again and you should be good.
Engine: 305 TPI LB9
Most cities have a tool specialty supplier. They can fix you up with the correct tap.
Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
