Throttle sticks open, only when engine running
Old Jun 30, 2011 | 08:49 PM
Kinka17's Avatar
Car: 89 Iroc Z Convertible
Engine: 5.7 TPI
Transmission: T-5 Manual
I'm trying to finally get my car back on the road. After replacing the MAF and the distributor, I finally have the car idling decent and its drivable. The issue I'm having is that while the car is off, you can move the throttle and it springs right back like it should. If you have the car idling, every so often it stays slightly open. If I open the throttle the entire way via the pedal, it stays pretty far open.
The only other problem i can see is that my Tach is WAY WAY off when it happens.
Old Jun 30, 2011 | 08:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Throttle sticks open, only when engine running
Probably needs throttle shaft bushings.
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
camaroken83
Aug 10, 2015 11:35 AM
