Starting issues
Old Jul 4, 2011 | 01:19 PM
chevyguy842010's Avatar
Car: 92 z28
Engine: 305 tpi
Transmission: automatic
Starting issues
i recently bought a 92 z28 with a 305 and 700r4. the car runs great once it starts. but it take anywhere from 15-30 seconds of cranking before it will start.
the car is completely stock. Any ideas ?
Old Jul 7, 2011 | 08:54 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Starting issues
bump
Old Jul 7, 2011 | 09:44 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
Re: Starting issues
Id say fuel pump. Before mine totally died on me it did the same thing, progressively getting worse.
Old Jul 15, 2011 | 03:13 PM
majobis's Avatar
Axle/Gears: G92
Re: Starting issues
Actually, as soon as this post went up, I started having the same problem. For instance, as soon as I turn the key on - but before starting - I wait until I hear my electric pump finish its whining prime. Then, I start it. However, if I shut it off and try to start it again within a half hour, it will just crank and I have to go old school (pumping gas pedal) to get it to start. Is this the problem both of you have/had?
Old Jul 15, 2011 | 06:57 PM
Car: 92 z28
Engine: 305 tpi
Re: Starting issues
well mine i will turn the key to on wait for fuel pump and i cycle the key that way 3 or 4 time and it still cranks for about 30 seconds, it seem like once the engine builds oil pressure then it will start right up, i can then shut it off and it will start it right up again.
Old Jul 15, 2011 | 07:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Starting issues
I'm look at replacing the fuel pump relay - helluva lot easier than the fuel pump, and cheap to try $10).
The oil pressure swending unit will kick in the fuel pump IF the relay is not working, but it takes a few seconds to register the oil pressure. Sounds like exactly what's happening.
Normally, the fuel pump primes (a programmed function of the ECM when key turned on), and then, when car staretd, the ECM will run the fuel pump as soon as it "sees" a steady ignition (distributor).
So, it's also possible (I suppose) that something might be wrong with your ESC, or distributor, or ECM as well. But I'd try a new relay first.
Old Jul 17, 2011 | 03:56 PM
Car: 92 z28
Engine: 305 tpi
Re: Starting issues
where abouts is that relay located ?
Old Jul 17, 2011 | 04:09 PM
Car: 1992 RS
Engine: Carbed 350
Re: Starting issues
On my TBI car, it was on firewall, driver side, inside a bracket between the fender and the brake booster - there were two relays there, one for fuel pump, one for electric fan. But exact location on a TPI car I'm unsure.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
