gasoline question
Old Jul 27, 2011 | 05:35 PM
Broone115's Avatar
gasoline question
I recently starting running 92 octane fuel in my 91 350 TPI (all stock) and it seems to run smoother and has more pull in the higher rpms (please dont tell me thats impossible because i definately feel a difference) I know somewhat about gasoline and the octane ratings and E10 and detergents and additives in the gas but my question is, since I now run 92 octane, should I advance my timing by a couple of degrees to get a more complete burn since this octane burns slightly slower?
Old Jul 27, 2011 | 06:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: gasoline question
Better to fix whatever's wrong to keep you from running 87.
Old Jul 27, 2011 | 06:14 PM
Broone115's Avatar
true, but im in the same boat as alot of people here, where their car becomes really sluggish and/or stalls due to excessive heat somewhere in the fuel system (i dont know, no one can figure it out) and i cant seem to fix that problem no matter what i do, or no matter what anyone does, i believe there are 2 ongoing threads right now about this problem, and running 92 octane seems to help, so should i advance my timing or no?
Old Jul 27, 2011 | 06:39 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
For your info: All TPI's require 92+ octane gas (per GM service manaual). Also the ECM adjusts the timing per the sensor imputs.
Old Jul 27, 2011 | 06:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Does it say "92+", or does it say "premium"?
Old Jul 27, 2011 | 06:51 PM
DJP87Z28's Avatar
Take your choice....I don't have the service manual in front of me... Lets say PREMIUM over REGULAR for TPI's
Old Jul 27, 2011 | 09:32 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
After reading this post, I had to satisfy my curiousity. Broone115 and DJP87Z28 are both correct.
Exact quote from the first paragraph of 'Fuel Requirements' from my 1987 owner's manual:
"Your engine is designed to operate on premium grade unleaded fuel. However, with the electronic spark control system, you may use regular unleaded fuel at slightly reduced acceleration performance".
Old Jul 27, 2011 | 10:07 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
If it runs better now, I would leave it. New plugs and dist cap and rotor for a clean burn is always nice too. Just remember that most aftermarket chips require a stock timing as they bump the timing at higher RPM"s.
Old Jul 28, 2011 | 12:25 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
premium is the only way to go . use shell gas for years
Old Jul 28, 2011 | 01:13 PM
Broone115's Avatar
thanks guys, when i bought my car it didnt come with the owners manual, the PO lost it, thanks for the clarification!
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Justin92GTA
Aug 27, 2015 11:16 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
