AFPR
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Re: AFPR
I've never seen one in a store. Online is a better bet.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: AFPR
There have been many posts on doing a DIY AFPR using the stock FPR. I tried to find the link, but couldn't. If you are in a hurry, you can do a google search to see if you can find it. It requires taking the FRP apart, and welding a Nut on the top. You then thread a screw into the nut. When you put the FPR back together, use something like a Quarter inside the FRP for theend of the bolt to ride against. When closed up, the bolt can be adjusted down, which will put pressure on the diaphragm and spring, and increase fuel pressure.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: AFPR
I wouldn't put a quarter under the stock cover. A quarter is way too thick!! Your fuel pressure will be stuck at a min. of 50 psi if you use a quarter. I have tried this idea out already.
Re: AFPR
I wish I could find the original post on this. It had good pictures and steps to follow. I remember something about using a hammer on the top part- maybe that was to provide a little room inside the cover for the adjustment. The quarter I seem to remember just as a flat piece of metal that the bolt could push down on against the diaphragm and spring. Oh well, I'll keep searching- maybe I can find the original discussion. For my setup, I used a Holley AFPR, and it seems to be dong fine.
2012sergen11
Oct 13, 2015 07:38 PM
