TBI to TPI
Old Aug 1, 2011 | 07:10 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
TBI to TPI
Ok so I'm swapping from TBI to TPI. My car is a '91 305 tbi and the donor that I ripped the parts off of was an 87 305 tpi (but we are not sure if motor was the originia, guy said it had been replaced, looked stock to me though)
I have from the TPI donor:
Upper Plenum assembly
Manifold
Fuel rail
Metal fuel lines off the rail
TB
Computer
some other main chipboard (not sure what its called)
complete Engine harness
Valve covers
Heads
I might have a couple other misc parts that aren't coming to my mind atm.
What I am wondering is will I be able to directly swap these parts into my car without too much hassel? Do I have all the parts that I need? Oh and I have the TPI fuel pump already installed in my car.
I know I could have done a search but frankly the Search feature has a bad return and didnt offer anything helpful. So if your going to post "Just do a search" please don't waste my time and yours, thank you.
Old Aug 1, 2011 | 11:09 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: TBI to TPI
Truthfully you're not gaining much from this swap. Side stepping is more like it. Take it from a guy that has BOTH TBI and TPI. My 305 TBI car is easily a mid 13 second car with the STOCK tbi unit. It just takes a little finesse and just a touch of patience. Either way you're going to need to spend quite a bit of cash just to do this swap when your money could be easily spent on actually making the car faster. Just read my cardomain, I've covered much of what you'll need there.
Old Aug 2, 2011 | 08:29 PM
Re: TBI to TPI
What would cost me? I have all the parts (I think)
Old Aug 4, 2011 | 09:50 AM
Re: TBI to TPI
Anyone else have any thoughts?
Old Aug 6, 2011 | 11:02 AM
Re: TBI to TPI
Anyone?
Old Aug 6, 2011 | 09:55 PM
Re: TBI to TPI
No thoughts? do i have to beg?
Old Aug 6, 2011 | 11:07 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: TBI to TPI
I think in 91 the engine harness and body harness are all in one. 87 had a engine separate harness. The swap may not be that easy due to that fact. However, if you really want to do it I know street and performance makes an interface harness that takes all the guess work out of it and turns it into a simple job.
http://hotrodlane.cc/
Also, you make a tbi car perform. May add an L31 350 Vortec motor for 2k with 255 hp, gears, exhaust, convertor, and you will be in the mid to low 13's no problem.
Old Aug 7, 2011 | 09:13 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Re: TBI to TPI
I would say plan for $600-$800 or so. You are bound to have bad sensors, injectors, so get ready for it. You will want to put a new pump in the tank. Would not want to spend all the time to put a used pump in the tank. You wont really get a lot of HP from the swap. You will get tons to torque though.
Old Aug 7, 2011 | 10:37 AM
Re: TBI to TPI
Really 600-800? All the sensors are working and so are the injectors, the car I took the TPI off of was running fantastic when we pulled it, was only pulled because we were told it was a 350, when it turned out to be a 305 I decided to pull the TPI stuff off and throw it onto my car.
Old Aug 7, 2011 | 10:53 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TBI to TPI
i think all u have to do is re-pin the existing harness. look for 746 to 165 ecm swap info.
Old Aug 7, 2011 | 10:54 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TBI to TPI
my car is a 91 tpi 350 ,used to be a 91 tbi. harness connector at the ecm was just re-pinned.
Old Aug 7, 2011 | 10:57 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TBI to TPI
why dont u just go with speed density instead? there is a sticky on here with the tbi /746 ecm to tpi/730 ecm re-pinning instructions.
Old Aug 7, 2011 | 11:20 AM
Re: TBI to TPI
what years were the speed densities? Im not sure what year tpi i have, I really need to go look at the parts, i literally have everything that was connected to that engine that had anything to do with the tpi.
Old Aug 7, 2011 | 11:24 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TBI to TPI
90-92. For an older tpi manifold you may have to get the 9th inj. block off plate. May also need tps for a SD and a few more sensors, not sure. Will be much easier and less maintenence with SD.
Old Aug 7, 2011 | 11:26 AM
Re: TBI to TPI
Ya im thinking that the tpi is from an 89 but im not sure i guess until i grab the #'s. Would the tps from my tbi work? or are they different? Also my tbi is Map but i have the Maf for the tpi
Old Aug 7, 2011 | 05:29 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TBI to TPI
https://www.thirdgen.org/tbitotpi
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
