What injectors (brand) came on these cars?
Old Aug 2, 2011 | 09:05 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I'm putting new injectors on along with my heads and whatnot and wanted to know what injectors these things came with. I have a 90 Formula, 305 TPI.
This is what I've been looking at: http://www.autozone.com/autozone/par...4_528140_7059_
Not a big fan of autozone's stuff though.
Old Aug 2, 2011 | 11:35 PM
Yager90IROC's Avatar
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Re: What injectors (brand) came on these cars?
check out southbay injectors, they are a site sponsor and have great injectors at low prices. Highly recommended. 305 has 19lb. injectors.
http://www.southbayfuelinjectors.com...o_305_TPi.html
Old Aug 2, 2011 | 11:46 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
from the factory it had muiltec injectors.
radi beat me to it.
in addtion to southbay there is also InjectorsPlus, both of which will get you a better injector than you'll get from the zone and for a better price too.
there is also Fuel Injector Connection, or FIC.
Old Aug 3, 2011 | 05:09 AM
Mr Froman's Avatar
Shooot. I need them by the weekend though : \
Old Aug 3, 2011 | 06:28 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
If you are not opposed to getting a set from the junkyard you can obtain ford/bosch yellow tops cheap enough. They came in just about every 4.6l v8, some v6s and some of their bigger v8s from 95ish to about 03. I'm running those in my 305 and it seems to be working real good. I think I paid about $20 for the entire set.
I think they are these ones that southbay lists, which honestly their price is pretty good considering they are cleaned and rehabed.
They also have the advantage of fitting in the fuel rail perfect with the stock clips
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
