odd revving / idle problem ..any help appreciated
Old Sep 3, 2011 | 10:36 PM
chrishh99's Avatar
Car: 1988 camaro iroc-z
Engine: 350 tpi
Transmission: t-5
Axle/Gears: 3.23 posi
350 tpi motor in my 1988 iroc that has an odd problem that i can't seem to figure out. after the motor is warmed up i'll come to a stop light, shift into nuetral and it will idle rather high, anywhere from 1500-3500. but if i just tap the gas it will fix itself and idle at about 800 or so. it almost feels as if the throttle cable is 'sticking' but after checking the cable out i can tell it's not sticking. could it be something vacuum related? any help is appreciated
Old Sep 4, 2011 | 12:09 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: odd revving / idle problem ..any help appreciated
I'm getting that too. Only now the engine is running ruff.Like it's flooding or missing on 2 cylinders.wounder if that spring thing needs lube spray?
Old Sep 4, 2011 | 06:29 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
same thing my TBI car does.. Everything on mine is new...
Old Sep 4, 2011 | 07:49 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
it would seem that someone out there in the third gen world would have figured this one out by now,Must be one of thoughs,it could be 20 different things type issues.Can the ECM send info to the TB to cause the throttle cable linkage to open slightly causing this?
Old Sep 5, 2011 | 12:23 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I talked to my son in law and read up in the repair manuel.2 thing manuel talks like the cable needs lubing in a couple of spots,also son in law said check in the TB where the flap moves and make sure theres not some kind of wear that could be interfearing with the operation.
Old Sep 5, 2011 | 09:30 PM
chrishh99's Avatar
Engine: 350 tpi
Transmission: t-5
ok im going to try and wd-40 the cable and see if that helps at all. i checked the TB and everything checks out ok there. ill let you guys know the outcome after i pick up some wd-40.
Old Sep 8, 2011 | 11:07 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
So did you find out the answer cause i have the same problem and its a pain!
Old Sep 10, 2011 | 04:12 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Leaning towards TPS adjustment perhaps....Am going to ream out the holes in mine, so I can adjust it..
Old Sep 11, 2011 | 01:43 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I have seen the cruise control cable be just close enough that it holds the throttle open, and when you "kick it down" the cruise cable is slammed far enough away to allow the throttle blades to shut. That cable is adjustable at the cruise unit. I've also had a TBI unit with a weak return spring and fixed it the lazy way by adding a spring like it was an old carb. I don't know if it helps but those are problems I've seen.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
wayshegoes
Aug 17, 2015 12:00 PM
