305 vs 350 TPI intake manifold
Old Sep 11, 2011 | 08:38 AM
ssor's Avatar
Hi guys!
I would like to know if the intake manifold, throttle body and injectors are the same on the 350 and the 305 TPI?
Thanks!
Old Sep 11, 2011 | 10:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 vs 350 TPI intake manifold
Injectors are different ;19lb for the 305 vs 22lb for 350.
Intake is the same but there are year by year differences.
See
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
Old Sep 11, 2011 | 12:10 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
In any given year they are the same. Aluminum head Corvettes are different because of EGR provisions. The TPI was originally built and sized for the 305 and was used "As is" on the 350 except for the addition of 22 lb injectors for the 350 engine. This was done to save money. The cost of a different part for a 350 could not be justified by the bean counters at GM. The TPI was so superior to the old "crossfire" system on the 350, that the difference in the two systems was startling to say the least. It was hard to say what would have been possible if a higher airflow capacity TPI had been built and used on the 350 HO engines. A lot of our troubles would have been eliminated!
Old Sep 11, 2011 | 02:30 PM
Eightyninef's Avatar
I have a complete Corvette top end.
heads (just redone by machine shop)
tpi intake
runners
plenum
1992rs/ss
Jan 31, 2025 05:10 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
