Coolant temp sensor question! Tunerpro RT
Old Sep 11, 2011 | 08:06 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
So i had my car Hooked up to my laptop using tunerpro RT.
I was trying to diagnose a bad idle situation, Lots of fluctuation in air/fuel and what sounds like timing.
It picks and chooses very randomly how it wants to run.
One minute it will run well, idle will even out, then it just DROPS. Starts to stink of rich exhaust. It even stalls.
--------The the coolant temp that the ECM was getting was 244 steadily, even when the car was cold. So i know thats bad.
Could that be causing all of this?!
I have replaced the ignition coil, cap, wires, plugs, TPS, IAC, ignition control module, pickup.
Ohm checked all injectors, theyre fine.
i have sufficient fuel pressure at the rail.
base timing has been set to 6* btc.
Minimum Air setting was set
Tps is at .54 v
Sprayed out MAF
Havent checked 02, knock sensor, MAF burn-off relay or power relay, or the ESC module.
CAN THE BAD COOLANT TEMP SENSOR CAUSE ALL OF THIS?! thanks!
Old Sep 12, 2011 | 01:05 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: Coolant temp sensor question! Tunerpro RT
Yes, yes it can.
If the CTS value never changed then it should be replaced. You are lucky; that's an easy fix.
Good luck
Old Sep 12, 2011 | 02:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by skibum2100
Yes, yes it can.
Think about it.
If the ECM doesn't know what temp engine is at ; how can it supply correct fuel and spark.
Old Sep 6, 2013 | 03:40 AM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Originally Posted by vetteoz
Think about it.
Where could I find a CTS sensor, no auto parts stores carry them
Old Sep 6, 2013 | 07:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
http://tpiparts.net/inc/sdetail/10956/497
Most parts shops have them , same sensor is used in TPI , TBI and LT1 engines
Going by your other post
https://www.thirdgen.org/forums/tech...se-help-2.html
you are confused about which sensor you want .
The one you say is not working is the cold start switch for the 9th injector ; not the coolant temp sensor (CTS)
Old Sep 22, 2013 | 07:49 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
NAPA auto parts has em. under $20 ... just put one in the camaro, now I think the GTA needs one ... getting code 33, put a new MAF in last year .... after a long ride, it started acting up, may just do an O2 and a CTS.
Old Sep 23, 2013 | 10:37 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Try the O2 sensor the coolant sensor is not your problem.
Old Sep 24, 2013 | 09:11 PM
Car: 90 Iroc Vert
Engine: 5.0L
Cool thanks. I will try that.
Old Sep 30, 2013 | 08:22 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Jersey did the 02 sensor solve your problem?
TheExaminer
Aug 26, 2015 04:59 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
tmellott89
Aug 16, 2015 02:58 PM
bamaboy0323
Aug 15, 2015 07:20 AM
