best head combo for a 305 with lt1
Old Oct 6, 2011 | 12:38 AM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
ayy guys wondering wat wouldbe a good head for a lt1 camin a 305 i dont know the math and on how to match emm
lift to intake
rotation to valves idk
love to learn how to butfigure i ask some good questions
Old Oct 6, 2011 | 01:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: best head combo for a 305 with lt1
camin a 305
Would help if you spoke English
u wanta hed 4 a LT1 enjun
or u putin a cam in ur 305?
Old Oct 6, 2011 | 07:12 PM
dabird07's Avatar
Car: 92 firebird
sry cam in engine
Old Oct 6, 2011 | 09:52 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
that's the best laugh i've had all day.....actually hurt myself....
Old Oct 6, 2011 | 10:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
sry cam in engine
Sorry, my Martian translator is not working today
Old Oct 6, 2011 | 10:20 PM
dabird07's Avatar
Car: 92 firebird
tbi to tpi
lt1 cam going into block
what would be a good head combo for this setup
hope that clears it up. . . .
Old Oct 7, 2011 | 01:02 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Budget ?
I suspect if you are going for better heads then you could use more cam than a LT1 cam.
LT1 cam is 305 is a cheapy mod on stock 305 engine
https://www.thirdgen.org/forums/post...115-post6.html
Old Oct 7, 2011 | 07:24 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I put an LT1 cam in an L69. Works pretty good with the 081 heads. They are hard to beat if you have to maintain emissions. Vortec heads are good, but the intake is expensive.
Old Oct 7, 2011 | 08:03 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Truthfully I'd go with ZZ4 heads and cam for a 305........you'll like it trust me,lol.
Old Oct 7, 2011 | 08:50 PM
dabird07's Avatar
Car: 92 firebird
i read ure car domain if i get my tbi heads ported do the flow better and would they run well on a tpi how much gain?
good read by the way and all v6 have a 3.42 gear in it??? im going to the yard
Old Oct 7, 2011 | 11:51 PM
dabird07's Avatar
Car: 92 firebird
also with posi?
Old Oct 8, 2011 | 04:35 PM
Honestly if you're going to pull off the heads you might as well put better ones on. The swirl port heads aren't "bad" when ported if you want a motor that doesn't pull past 4500-5000 rpm (with tpi you're kinda stuck there as well stock) They make great torque for the street but you'll run out of steam pretty quick. The v6 cars do come with 3.42's but in an open diff. Get an Eaton posi. it's good money spent IMHO.
Old Oct 8, 2011 | 05:00 PM
dabird07's Avatar
Car: 92 firebird
i will keep this in mind its more of a budget build for me and i here those tbi heads are terrible stock im bout to go to the junkyard hehe
those zz4 heads need work from wat i read and where could i get em for cheap?
also if u dont mind look at my forum where i compared my cams with info help plz
Old Oct 8, 2011 | 05:03 PM
dabird07's Avatar
Car: 92 firebird
https://www.thirdgen.org/forums/tbi/...stock-cam.html
Old Oct 8, 2011 | 05:53 PM
ZZ4 heads don't necessarily "need" alot of work really. Just get them shaved down about .030 to get the combustion chamber down to about 55cc (anybody correct me if i'm wrong) so your compression stays about the same due to aluminum dissipating heat faster. I would also get the bowls cleaned up especially around the valve guide and do a good gasket matching of the ports. After that you should be golden with them on your 305.
Old Oct 8, 2011 | 06:59 PM
dabird07's Avatar
Car: 92 firebird
how much money would this take??? in case i go this route and wat wus the gains???
1984HO
Mar 19, 2021 11:59 AM
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
