Will a TPI intake fit on this?
Old Oct 10, 2011 | 10:47 AM
gold_81_camaro's Avatar
Car: 1991 Camaro RS
Engine: TBI 305
Axle/Gears: 3.08
Im about to start pieceing together my tpi build for my car and was wondering if a tpi intake would fit on a 350 4 bolt main out of a 71 camaro? This is the original motor so no question about the year. Just need to know if it will mate up or not. If not what years will the tpi mate up to?
Old Oct 10, 2011 | 10:52 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Will a TPI intake fit on this?
The block itself will not make a difference.
A 84-86 TPI intake will fit the early perimeter bolt valve cover heads. 87+ TPIs will have to run the center bolt valve cover heads.
Old Oct 10, 2011 | 12:28 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
If you are using old heads, you have to elogate the holes in the intake. Early maniflod bolts go in at an angle newer style stright up. As gentlemen said above look at valve covers and will tell you which head you have. You will have to put in a cam that will run with tpi or you will go crazy tuning it. I have a old style lower tpi intake if you need one PM me if you need it.
Old Oct 11, 2011 | 06:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Some aftermarket intakes come with the elongated holes so the one intake fits both style heads
1992rs/ss
Jan 31, 2025 05:10 PM
masonta
Aug 31, 2015 10:14 PM
kyle5647
Aug 15, 2015 11:56 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
