L98 wont stay running?
Old Oct 8, 2011 | 12:52 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so the car has been running great as of lately but we had some pretty extreme rain on wednesday and i unfortunately had to get to class so i had to drive in it.
i went back out to my car yesterday and it wont stay running.
i can keep it running if i keep my foot on the gas but as soon as i let off..it dies
i know its not the ECM because the ses light still blinks twice at ignition and only throws a code 12.
what could the problem be? could the rain have got to something?
Old Oct 8, 2011 | 01:15 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: L98 wont stay running?
oh and i really need to get this figured out before monday because i have class..
Old Oct 9, 2011 | 04:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
could it be the alternator?
Old Oct 9, 2011 | 05:42 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
injectors probably. http://www.youtube.com/watch?v=_g8PdrT0MCU
nice car btw,looks like mine!
Old Oct 9, 2011 | 06:04 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If you keep giving it gas for a good minute or so, will it then stay idling by itself? Drives perfectly fine, yet won't idle. Idles poorly, but stays idling? Then once it will stay idling, but poor, will it idle nice & smooth after a few minutes?
I'm currently fighting that issue & it is looking as if the O2 sensor is the culprit.
Old Oct 9, 2011 | 08:53 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks
but its not the injectors..
it will only start if i give it gas..havent tried to put it in drive..but it'll rev up and sound great but as soon as i let off it dies
Old Oct 9, 2011 | 08:58 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
well i know that when it rained really hard a couple months ago my car did the same thing.... come to find out that somehow water got into the maf relay sensor on the firewall and causing all sorts of hard starts and stalling issues.. i took the relay out and water was all in there.... replaced that and the other sensors on the firewall and never had a problem since...
Old Oct 9, 2011 | 09:03 PM
Car: GTA
thanks
Sounds exactly like mine right now. If I keep giving it gas for a few minutes for the O2 sensor to start warming up, it will stay running, but still rough. Keep it running a little longer, for the O2 sensor to get even warmer & it will end up idling just as smooth as ever. Takes about 5min plus for the sensor to get fully warmed up, but perfectly drivable when it gets there.
Try giving it gas long enough for it warm up & see if that helps.
Old Oct 9, 2011 | 09:06 PM
88fastgta's Avatar
also make sure you dont have any moisture in your dizzy area or better yet under the dizzy.... that will also cause an extremely hard start and casue problems....
Old Oct 9, 2011 | 09:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm..ima go check right now..will post back up
okay but if it does do that once its warm does that mean its the O2? just replaced it with a bosch one
will check right now as well
thanks guys
Old Oct 9, 2011 | 10:07 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
doesnt seem to be many moisture..
Old Oct 9, 2011 | 10:36 PM
Car: GTA
If you just replaced yours, it's not likely (but not entirely impossible) that the 02 sensor is bad.
Old Oct 9, 2011 | 10:37 PM
ninetyone's Avatar
Axle/Gears: 3:42
how do u know it's not injectors? did you test them? hey, unplug the maf and see if it runs better. Mine acted like your car when my prom went bad, and yes i still got code 12 as normal. Car just ran like it was stuck in diagnostic mode. Could be the ecm too. Does your car ping when you take it past 3k rpm?
Old Oct 9, 2011 | 10:39 PM
ninetyone's Avatar
Axle/Gears: 3:42
once i had a loose 02 sensor and drove through a puddle and car died like that,but it gave me a code.
Old Oct 10, 2011 | 12:02 AM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Out of curiosity did you unhook the battery for 10 minutes and re hook it back up?
Old Oct 10, 2011 | 11:57 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
it was the IAC..thanks guys
Old Oct 11, 2011 | 12:11 AM
Car: GTA
Details? Location? Parts link?
This? http://www.autozone.com/autozone/acc...er=891210_0_0_
Mine started acting weird today. Rough idle would suddenly smooth out, then go rough again. Obviously something was working/not working/working, but tracing it....ARGH!
Old Oct 11, 2011 | 01:52 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
didnt buy the comp cams one but yeaa
when they go bad..the car cant control the air it needs to stay idle..its right below the throttle body..
Old Oct 11, 2011 | 09:17 AM
Car: GTA
You ever get a trouble code?
I can see the IAC being my problem despite my MAF code. https://www.thirdgen.org/forums/tech...-misfires.html
because it drives fine after warmed up, but idles like crap.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
TheExaminer
Aug 19, 2015 10:07 PM
