How To: Installing New Injectors
Old Dec 12, 2011 | 06:42 PM
tylerf's Avatar
Just got some new fuel injectors, question about installing them.
When installing should i attach to the fuel rail first or to the manifold. Also is there any kind of lube, sealant, or oil that i should be using when installing, if so where? (o-rings on injector, the holes in the manifold etc..)
I bought my injectors from southbay they are the yellow tops for tpi 305 19lb
Thanks guys you are all great!
Old Dec 12, 2011 | 06:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How To: Installing New Injectors
install them on the rail first, a light coating of petroleum jelly works good as a lube for the o-rings.
Old Dec 12, 2011 | 06:58 PM
SaltLifeCamaro's Avatar
Car: 86' Iroc-Z
Engine: tpi 350 small block
Transmission: a4 :)
Axle/Gears: bone stock for now
attach them to the fuel rails first, i didnt use any lube or oils and have had no problems with that. mine are for the 350 tpi but same exact concept.
Old Dec 12, 2011 | 08:12 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Do not use any product that are petrolium based. WGiven enough time and heat it will breakdown most O-ring seal materials. Use a water based lubricant. I steal my wifes Avon hand lotion. Being water based it eventually evaporates.
Old Dec 12, 2011 | 08:23 PM
Engine: Lb9
Transmission: M20
O-rings in atomotive engine applications are neoprene and not affected by petroleum products.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
