PLEASE HELP 350 tpi help needed
Old Dec 20, 2011 | 09:00 AM
camarotime's Avatar
Car: 1986 Irocz
Engine: Modified TPI
I am currently working on a 85 vett with a 350 tpi in it. Every time we go to start it we hear a hissing noise coming from under the upper plenum, it will turn over but never start. When you stop turning it over the noise returns for a good 5 to 10 seconds depending on how long you turn the engine over. The car has all new injectors in it, new spark plugs, and a new fuel pressure regulator. Any help would be greatly appreciated. We are at a stand still on where to go next.
Old Dec 20, 2011 | 01:14 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
Re: PLEASE HELP 350 tpi help needed
.. How did the old sparkplugs look? Oil fouled? Wet? Dry? White, grey, or tan insulator?
.. How are the new plugs now? Wet? Dry? Clean?
.. Got spark at a plug when cranking it?
.. Take a fuel pressure reading now?
.. Check ignition timing with a timing light? Maybe a worn out timing chain slipped cam/ignition timing?
.. Compression check on all 8 cylinders? A leaking valve may be giving the hissing sound. But it should still start.
.. When key turned on, fuel pump relay gives 2 seconds of pumping... then oil pressure switch supplies juice to pump from then on after starting...
IROCZ1989
Jan 24, 2016 03:55 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
