VSS question
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
VSS question
Im in the process of swapping a SD TPI harness into my car. The harness that I have has the connector that goes to the electric speedo within the trans for VSS and an electric speedo. How can I use my current setup that has a mechanical speedo and vss buffer attached to the back with this harness while keeping the ecm happy.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS question
you can use the speed buffer signal 2k ppm and input it to the 730's b10, this will require you to change the check sum in the eprom to optical vss. The 4k directly to pin b9 and b10 will work but since you will need to get your vats reprogrammed out of the memcal.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: VSS question
Engine: Lb9
Transmission: M20
Re: VSS question
I assume you have a 1227165 it would be a10 to the 730 b10 I am not sure of the address of the change from magnetic enabled to disabled I have tunercat and you just uncheck the enabled magnetic vss box. I am out of town right now and will post it on tuesday if you like or if you ask user rbob I'm sure he knows right away.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: VSS question
Yes I have the 165 ecm in the car now and will be going to the 730. The 730 harness has the vss at the trans where mine is on the back of speedo and was not sure how to get the signal from the speedo to the ecm. I use tunerpro rt but have not tried or even looked at the bins or xdf files yet. Want to get the harness in order first. For all I know it may a flag in the xdf. None the less, if you can get me that location and what the value is, that would be great.
So b9 and b10 on the 730 harness would have to go to the dash harness connector that is connected to the vss input and ground. On the 730 ecm, connector b11 is the vss output. Is that the wire used by the speedo to indicate speed?
Engine: Lb9
Transmission: M20
Re: VSS question
just b10 on the 730 needs to goto the buffer on pin F. I will get you the address and change
Engine: Lb9
Transmission: M20
Re: VSS question
on optical setup yes, when used a magnetic b9 is a ground. I am fooling around now and looking at the change it actually changes alot of the address. want to pm me with your email address maybe its better I just send you a aujp with no vats and the magnetic vss turned off. I have everything now loaded onto this computer.
Engine: Lb9
Transmission: M20
Re: VSS question
This is a aujp with the magnetic vss turned off and optical enabled.
Car: 86 IROC
Axle/Gears: BW 3.27
Re: VSS question
Thanks. Just taking a quick glance, it looks like values 3-8 are the only ones that are changed.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
