MAP sensor/vac connection
Old Jan 21, 2012 | 03:16 PM
TPIMonteLS's Avatar
Transmission: Automatic!
Does anyone have a good picture (or can describe) where the line from the MAP sensor on a SD TPI engine feeds into/from? Also the port just to the right of the MAP sensor as mounted on the plenum, where that would lead to. I realize I might of answer my own question if the line from the MAP goes directly into the plenum next to it . Just want to be sure.
Old Jan 21, 2012 | 04:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAP sensor/vac connection
I don't have a picture handy but the last one closest to the bulk head is the map the next one to the right is the fuel pressure regulator and the one up hight off by it self is the hvac.
Old Jan 22, 2012 | 10:09 AM
TPIMonteLS's Avatar
Thank you. I did find a picture that kind of shows it:
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
Just need to find a vac fitting now for the right side port to move the HVAC line to, currently there is a bolt in it's place.
$750 L98
Feb 1, 2025 02:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
gta892000
Sep 16, 2015 12:37 AM
