stock 89 tpi intake
Old Feb 6, 2012 | 09:24 PM
c4ta's Avatar
Car: 89' GTA,98' z28
Engine: 350tpi/ls1/ls6
Transmission: 700r4/4L60e
Axle/Gears: BW 3.27/3.42
stock 89 tpi intake
i am looking for new heads after relizing i dont want to spend 500 on a vortec intake. all the aluminum heads i have been looing at are drilled for 86-earlier and vortec. what is everyone doing to run their stock (ported) manifolds? elongating the 4 center holes? and anyone have some pics thanks
Old Feb 7, 2012 | 11:05 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: stock 89 tpi intake
There is no way around it. If you wanna run vortec heads with TPI , then you will need the lower base. You would not only have to drill the stock lower intake ,but you would have to add/weld metal to the intake cause the vortec heads sit at a different angel and it would leak otherwise.
Old Feb 7, 2012 | 11:20 AM
c4ta's Avatar
I won't be running vortec heads anymore. The heads I m looking at are drilled for both 86-older and vortec intakes. I want to run my stock ported intake on these heads so I just want to see what people are doing to run there tpi base on carb heads.
1992rs/ss
Jan 31, 2025 05:10 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
