Bolting 4L60E Trans To 350 TPI Question
Car: 1986 Camaro
Axle/Gears: 411
I Want To Swap Out My 700r4 With A Electronic 4L60E Transmission, I Know I Need The Brain From A '98-02 Camaro & Also The 4L60E Cross Member For 3rd Gens. Is There Anything Else I Need To Know Or Get? Thanks.
-Chris
-Chris
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
Re: Bolting 4L60E Trans To 350 TPI Question
You need a pcm from a 01-02 express van thats a 411 pcm, add a vortec dizzy and vortec 4x crank sensor
Car: 1986 Camaro
Axle/Gears: 411
it was what they used with the 5.7 vortec engine and a ls1 pcm. google 411 swap
Car: 1986 Camaro
Axle/Gears: 411
Did the 98-02 f-bodies use the ls1 engine? if so you would also need to a 24x crank sensor and coil near plug and all the extra's. Your looking at alot more money then going with a 411 pcm which is a ls1 pcm and a express van calibration and a vortec dizzy and 4x sensor.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Ask 1989GTATransam. He can tell you what to do because he has done it. Or maybe ask Dyno Don. He knows something about also.
84z96L31vortec
08-20-2017 12:16 AM
