Another ID these connectors thread
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
91 L98 speed density harness, motor from an 87
can someone help ID these connectors
Also:
Does the 91 use the egr temp sensor? Where is the connector located if it does?
Anyone have a pic of the connector / wire routing for the coolant temp switch for the gauge, i cant find it on my harness.
pic 1 : assuming the puplre wire connector is for the 02 sensor what is the 1 prong green wire connector for?
pics 2 and 3 are the same - whats that for? also in pic 2 notice the sensor in the power steering line, no connector for that?
Also:
Engine: 5.7 L98
Re: Another ID these connectors thread
pic 1 and pic 2 - ac stuff? that has been deleted
pic 3 same as pic 1 in first post
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
pic 1 coolant temp sensor for you gauge between cylinder 1 and 3, and purple wire oxygen sensor. pic 2 looks like a fuse needs to go in there
post 2 pic 1 not used for air pump and a/c switch
Engine: Lb9
Transmission: M20
not many of the 1227730 wire wired up to use the power steering switch . I think it was based on tire size option
Engine: 5.7 L98
how does that kind of connector fit into that kind of switch? do i have the wrong switch?
Engine: Lb9
Transmission: M20
wrong sensor, is that a 2 wire cts ?
Engine: 5.7 L98
Engine: Lb9
Transmission: M20
