Fuel Pump Help Needed
Old Mar 12, 2012 | 10:39 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I just pulled the bad fuel pump out need some recommendations. I pulled it the correct way, by lowering the tank, not cutting the hole. Yes it was a pain but the old one is out. Anyway, for you guys that have replaced your pump, would you recommend replacing the sending unit. Keep in mind this is from an '85 Iroc. Also, what fuel pump would you recommend as a replacement. Internal or External and which one? Thanks.
Old Mar 12, 2012 | 12:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump Help Needed
AC DELCO EP241, if you fuel gauge is not working a spectra FG20A
http://www.ebay.com/itm/SPECTRA-PREM...ht_1108wt_1061
http://www.ebay.com/itm/NEW-AC-DELCO...ht_1935wt_1061
Old Mar 12, 2012 | 05:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
According to the listing you gave for the AC Delco, it is not compatible with an 85 TPI IRoc.
Old Mar 12, 2012 | 06:04 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Nevermind. I think the compatability check on the ebay listing is messed up because when I look at SummitRacing, they list that as one of the options.
Old Mar 12, 2012 | 06:40 PM
Engine: Lb9
Transmission: M20
yes, the acdelco application listings are not always complete or correct.
Old Mar 16, 2012 | 10:48 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
After doing some research and calling SummitRacing it looks like the ACDelco EP241 is will NOT work for my car. Any other suggestion from you guys that have an 85 TPI that has replaced their fuel pump?
Old Mar 16, 2012 | 11:08 PM
Rocky1974's Avatar
Car: 87 IROC
Axle/Gears: 7.75in. 3.27 Positraction
I put a Walbro 255 lph in my 87 TPI 350.
Old Mar 19, 2012 | 06:12 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
This is the recommendation I got from www.Hawksthirdgenparts.com. Is this really needed for the Walbro pump?
http://www.hawksthirdgenparts.com/85...pumpkit-1.aspx
Old Mar 21, 2012 | 11:02 AM
Engine: Lb9
Transmission: M20
not sure why your apposed to the ep241 it's a great pump.
http://parts-catalog.acdelco.com/cat...tock_check.php
Old Mar 21, 2012 | 06:58 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I have found nothing that tells me that this pump works for an 85 Iroc. Even when I called AC Delco, they say that the only Irocs that is works for is 89-90.
Old Mar 21, 2012 | 07:03 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
EP241 is correct for your 85 Iroc TPI.
Old Mar 21, 2012 | 07:34 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Originally Posted by tunedperformanc
Ordering tomorrow. Thanks guys.
Old Mar 22, 2012 | 08:25 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
Has anyone found this AC Delco EP241 kit any where besides the ebay link? Not crazy about the feedback that seller has....
Don't mind paying a few bucks more for better customer service/shipping.
Old Mar 22, 2012 | 08:29 PM
darrlee's Avatar
Car: 85 IROC
Or has anyone delt with this company?? Looks like a good deal as well. A lot of people on ThirdGen talk good about this one. I'm not oppsed the AC Delco, just don't want to get burned by a bad seller/company
http://www.highflowfuel.com/i-478372...1985-1997.html
Old Mar 22, 2012 | 08:39 PM
Engine: Lb9
Transmission: M20
rockauto.com, summitracing or oewarehouse.com
Old Mar 24, 2012 | 09:46 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Well, I ordered the pump and sending unit today. Got a good deal on the sending unit ($90). Hopefully it will all be here soon.
Old Mar 25, 2012 | 09:25 PM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
PLEASE FOR THE LOVE OF GOD DO NOT DO AN EXTERNAL FUEL PUMP. LMAO I went through hell on these damn things.
Old Mar 26, 2012 | 05:45 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I'm not. I'm sticking with the in tank fuel pump. It is a pain in the butt to replace but I've made it this far.
Old Mar 31, 2012 | 02:11 PM
darrlee's Avatar
Car: 85 IROC
OK, guys got a question...
Got my new pump and about to install it, here's my question though..
Since I dropped the tank, I just want some piece of mind before I put the tank back in, is there any way to test the pumo beforeI pu it in? can i just put 12v to it to make sure it runs?
Old Mar 31, 2012 | 03:18 PM
davidjr74's Avatar
Engine: 350 tpi
Yes. Run a wire from the positive of your battery to your fuel pump to be sure it turns on.
Old Apr 1, 2012 | 03:32 PM
darrlee's Avatar
Car: 85 IROC
OK, got the new pump in and its runnin great. Thanks for all the help!!
Old Apr 15, 2012 | 08:40 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Same here. The fuel pump is in and the car has fired up fine. Now to get all of the other stuff put back together. I need to replace the swaybar endlinks. I had to break one of mine to get it off. It doesn't matter I was going to replace them anyway. Any suggestions on replacements. I am going to bead blast the swaybar and panhard bar before I reinstall them. Probably painting them red.
Old May 2, 2012 | 08:27 PM
jlex300's Avatar
Car: 1987 IrocZ28 350
Has anybody looked into this ...... Jcwhitney.com. Part # sp20a1H
Spectre premium is the company.
Says it's the pump and sending unit for only $119. Free delivery.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
