D/S SLP runner top EGR port open & creating vacuum leak
Old Mar 15, 2012 | 07:32 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So I am finishing up my swap and the vehicle is running real rough. Found a huge vacuum leak created by the top of the SLP runner on the D/S the EGR port is open, there seems to be no place on the plenum
for it to connect to.
The SLP runners are the early ones with the 9th injector hole and the plenum I think is a 91-92 SD. Is the difference in the runners more then just the 9th injector which has been plugged off?
What should I do? Has anyone seen this before or know what im talking about?
Old Mar 15, 2012 | 08:45 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: D/S SLP runner top EGR port open & creating vacuum leak
If I remember correctly its because you put a V belt drive on the front of the motor.
J/K
I had to do something like this before. I used a tap and pipe plug(with sealer) inside the top of the runner.
Also make sure the upper gasket is on properly. There is a left and right. 2 of the lowers have a left and right also.
Old Mar 15, 2012 | 08:55 AM
insomniac's Avatar
Engine: 5.7 L98
yeah i guess i only need to plug the top, correct?
i was thinking of using some of that jb weld stick
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
